Specifically designed for stationary 360° shots, this tripod selfie stick captures expansive scenes from optimal angles with rock-solid stability. Its lightweight yet durable build unfolds quickly *, ensuring a smooth and efficient shooting experience.
* Suitable for stable, level surfaces in windless environments. Do not use while in motion.
Tips
1. Be careful to avoid pinching your fingers when folding the tripod.
2. Ensure the tripod is placed on a stable, windless surface during use.
3. Before storing the selfie stick, make sure to remove any sand or debris from the surface. If the selfie stick comes into contact with seawater, rinse it with fresh water and dry it thoroughly before storing.
Osmo 1.6m Tripod Selfie Stick × 1
Dimensions (Folded): Length approx. 347 mm, Diameter approx. 38 mm
Dimensions (Unfolded): Length approx. 1600 mm, Diameter approx. 502 mm
Weight: Approx. 378 g
Osmo Nano
Osmo 360
Osmo Mobile 7
Osmo Mobile 7P
