Featuring a built-in high-capacity battery of approximately 15.5 Wh, the battery extension rod magnetically connects to Osmo 360 and extends 8K/30fps video recording time up to 4.5 hours*. The rod extends up to 90 cm and supports camera controls like sleep/wake, record start/stop, and more. The quick-release design offers two adjustable positions, enabling seamless switching between invisible selfie stick shots and single-lens selfies.
* Measured under laboratory conditions at 25° C (77° F), while recording 8K/30fps 360° video, with Wi-Fi off, Gesture Control off, Voice Control off, Editing Assistant off, and the screen off. Data was collected in a controlled environment and should be taken as reference only. When activating and using Osmo 360 in the EU and the UK, actual battery life may vary due to local regulations on product operating temperatures. Refer to the actual user experience.
Tips
1. When using the invisible selfie stick feature, adjust the adapter to the 0° position to ensure the selfie stick and camera are aligned in the horizontal direction.
2. The product is not waterproof. Do not use it underwater or in environments with corrosive liquids like seawater to avoid the risk of battery combustion or explosion.
3. The rod features a built-in retractable spring cable and is recommended for handheld use only. Do not use in high-frequency vibration environments to prevent noise caused by collisions.
4. Do not place the product near heat sources, such as inside a vehicle under direct sunlight.
5. Before mounting the camera, ensure that the charging contacts on both the camera and the extension rod are clean and dry. Do not subject the product to mechanical impact, crushing, or throwing, and avoid violent shaking to prevent damage to the extension rod.
6. Before storage, remove sand and other foreign objects from the surface of the rod to prevent damage.
Osmo 360 Extension Rod × 1
Wrist Strap × 1
Battery Capacity: Approx. 15.5 Wh
Weight: Approx. 289 g
Dimensions (Collapsed): Approx. 217 × 40 × 49 mm (L × W × H)
Dimensions (Extended): Approx. 909 × 40 × 49 mm (L × W × H)
Joint Angle (two stops): 0°, 68°
Osmo 360
