  • 1-Inch 360° Imaging [1]
    Specially designed for 360° capture, the all-new square HDR image sensor maintains the same 360° image field as a traditional 1-inch sensor [1], while increasing sensor utilization by 25%.
  • Native 8K & Superb Low-Light
    DJI's first camera to offer native 8K 360° video with large 2.4μm pixels [5]. 13.5 stops of dynamic range, capturing sharp, vibrant footage—even in high-contrast scenes like city nights.
  • 4K/120fps & 170° Boost Video
    In single-lens mode, switch to Boost Video mode for a 170° field of view and buttery-smooth 4K/120fps footage. Experience next-level clarity and coverage.
  • 120MP 360° Photo
    With a single press, Osmo 360 lets you capture 360° photos at up to 120 megapixels (16K), revealing razor-sharp detail and a sweeping field of view. Experience true immersion like never before.
  • 100-Min 8K/30fps Continuous Recording [2]
    A high-performance imaging chip paired with an advanced cooling design enables continuous 8K/30fps recording for up to 100 minutes [2], and up to 190 minutes of recording [6] when capturing 6K 360° video.
  • 10-bit & D-Log M Color Performance
    All video formats support 10-bit color depth, capturing over a billion colors. D-Log M mode further expands dynamic range, preserving more details for greater flexibility in post-production.
  • Osmo Magnetic Quick-Release Ecosystem
    Compatible with Osmo Action series accessories and is equipped with a 1/4" thread hole. Easily switch between shooting modes with the selfie stick and adjustable quick-release adapter [7].
  • OsmoAudio™ Direct Microphone Connection[8]
    Connects directly to two DJI Mic transmitters for high-sample-rate audio—no receiver needed—capturing you and your partner's voices. With Built-in Mic Audio Backup enabled, ambient sound recording is also supported.
  • Osmo 360
    Osmo 360
  • Osmo 360 Camera Protective Pouch
  • Osmo Lens Cleaning Cloth
  • USB-C to USB-C PD Cable (USB 3.1)
  • Osmo 360 Rubber Lens Protector
  • Osmo Motorcycle Heavy-Duty Mount
Moments By You
1. When capturing 360° content, Osmo 360's CMOS sensor features an imaging area equivalent to that of a 1-inch CMOS sensor with a 4:3 aspect ratio.
2.Measured under laboratory conditions at 25° C (77° F), while recording 8K/30fps 360° video, with Wi-Fi off, Gesture Control off, Voice Control off, Editing Assistant off, and the screen off. Data was collected in a controlled environment and should be taken as reference only. When activating and using Osmo 360 in the EU and the UK, actual battery life may vary due to local regulations on product operating temperatures. Refer to the actual user experience.
3. Recommended for handheld use only. Do not use in environments with strong vibrations. For vehicle-mounted applications (e.g., motorcycles or cars), use the High-Strength Carbon Fiber Invisible Selfie Stick together with the appropriate stabilizing accessories.
4. When mounting on a vehicle for third-person perspective shots, always use it with the Dual Heavy-Duty Clamp and the High-Strength Carbon Fiber Invisible Selfie Stick.
5. "DJI's first" refers to Osmo 360 being DJI's first camera, as of its launch date on July 31, 2025, to feature two 4000 × 4000 square sensors capable of capturing native 8K 360° video with 2.4 μm large pixels.
6. Measured under laboratory conditions at 25° C (77° F), while recording 6K/24fps 360° video, with Endurance mode on, Wi-Fi off, Gesture Control off, Voice Control off, Editing Assistant off, and the screen off. Data was collected in a controlled environment and should be taken as reference only.
7. The Osmo 360 Standard Combo does not include an Invisible Selfie Stick, which can be purchased separately.
8. Direct connection to the first-generation DJI Mic is not supported. DJI microphones are sold separately.
