Osmo 360 Vlog Combo
Select Option
1-Inch 360° Imaging [1]
Specially designed for 360° capture, the all-new square HDR image sensor maintains the same 360° image field as a traditional 1-inch sensor [1], while increasing sensor utilization by 25%.
Native 8K & Superb Low-Light
DJI's first camera to offer native 8K 360° video with large 2.4μm pixels [5]. 13.5 stops of dynamic range, capturing sharp, vibrant footage—even in high-contrast scenes like city nights.
4K/120fps & 170° Boost Video
In single-lens mode, switch to Boost Video mode for a 170° field of view and buttery-smooth 4K/120fps footage. Experience next-level clarity and coverage.
120MP 360° Photo
With a single press, Osmo 360 lets you capture 360° photos at up to 120 megapixels (16K), revealing razor-sharp detail and a sweeping field of view. Experience true immersion like never before.
100-Min 8K/30fps Continuous Recording [2]
A high-performance imaging chip paired with an advanced cooling design enables continuous 8K/30fps recording for up to 100 minutes [2], and up to 190 minutes of recording [6] when capturing 6K 360° video.
10-bit & D-Log M Color Performance
All video formats support 10-bit color depth, capturing over a billion colors. D-Log M mode further expands dynamic range, preserving more details for greater flexibility in post-production.
Osmo Magnetic Quick-Release Ecosystem
Compatible with Osmo Action series accessories and is equipped with a 1/4" thread hole. Easily switch between shooting modes with the selfie stick and adjustable quick-release adapter [7].
OsmoAudio™ Direct Microphone Connection[8]
Connects directly to two DJI Mic transmitters for high-sample-rate audio—no receiver needed—capturing you and your partner's voices. With Built-in Mic Audio Backup enabled, ambient sound recording is also supported.
Osmo 360
× 3
Osmo Action Multifunctional Battery Case 2
Osmo 360 Camera Protective Pouch
Osmo Lens Cleaning Cloth
USB-C to USB-C PD Cable (USB 3.1)
Osmo Adjustable Quick-Release Adapter Mount
Osmo 1.2m Invisible Selfie Stick
Osmo 360 Rubber Lens Protector
DJI Mic USB-C Charging Cable
DJI Mic Mini Transmitter (Infinity Black)
DJI Mic Mini Windscreen (Black)
DJI Mic Mini Clip Magnet
DJI Mic Mini Transmitter Charging Dock (Infinity Black)
Moments By You
What are the highlights of Osmo 360?
1. Osmo 360 is equipped with 2 new-generation 1/1.1-inch square CMOS sensors. The square design enables the camera to deliver panoramic coverage equivalent to that of a 1-inch sensor.
2. High-brightness OLED touchscreen for clearer display and more convenient operation.
3. Wi-Fi 6.0 and USB 3.1 for fast data transfer.
4. 128GB built-in storage (105GB available); expandable via microSD card.
5. Battery life supports up to 100 minutes of 8K/30fps panoramic video recording*.
6. Battery life supports up to 190 minutes of 6K/24fps panoramic video recording**.
See the official product page for more product highlights.
* Tested under laboratory conditions at 25℃ with Wi-Fi, Gesture Control, Voice Control, and Editing Assistant turned Off, while recording 8K/30fps panoramic videos with the screen off. Data was collected in a controlled environment and should be taken as reference only. In the EU and UK, due to local regulations on operating temperature, the actual battery life of Osmo 360 may differ from the data shown on this page. Please refer to your actual experience.
** Measured under laboratory conditions at 25° C (77° F), while recording 6K/24fps panoramic video, with Endurance mode on, Wi-Fi off, Gesture Control off, Voice Control off, Editing Assistant off, and the screen off. Data was collected in a controlled environment and should be taken as reference only.
What are the advantages of Osmo 360's native 8K panoramic videos?
Osmo 360 features 2 newly designed square CMOS sensors with optimized pixel arrangement, increasing the sensor's vertical pixel count from 3,000 in the traditional rectangular sensor to 4,000. This enables native 8K (4K+4K) panoramic video recording with dual lenses. With large 2.4 μm pixels for enhanced light sensitivity and up to 13.5 stops of dynamic range, combined with an f/1.9 aperture, it delivers flagship action camera-level performance in both high dynamic range scenes and low-light environments.
What resolution settings does Osmo 360 support?
Supports the following resolutions:
Normal:
- Panoramic Video:
8K: 7680 × 3840@24/25/30/48/50fps
6K: 6000 × 3000@24/25/30/48/50/60fps
4K: 3840 ×1920@100fps
- Single Lens - Video:
5K (4:3): 5120 × 3840@25/30/50/60fps
5K (16:9): 5120 × 2880@25/30/50/60fps
4K (4:3): 3840 × 2880@25/30/50/60fps
4K (16:9): 3840 × 2160@25/30/50/60fps
2.7K (4:3): 2688 × 2016@25/30/50/60fps
2.7K (16:9): 2688 × 1512@25/30/50/60fps
- Single Lens - Boost Video
4K (4:3): 3840 × 2880@25/30/50/60/100/120fps
4K (16:9): 3840 × 2160@25/30/50/60/100/120fps
4K (9:16): 2160 × 3840@25/30/50/60/100/120fp
2.7K (4:3): 2688 × 2016@25/30/50/60/100/120fps
2.7K (16:9): 2688 × 1512@25/30/50/60/100/120fps
2.7K (9:16): 1512 × 2688@25/30/50/60/100/120fps
- Single Lens - Livestream:
1080p (16:9): 1920 × 1080@30fps
SuperNight:
- Panorama Video:
8K: 7680 × 3840@24/25/30fps
6K: 6000 × 3000@24/25/30fps
- Single Lens - Boost Video:
4K (4:3): 3840 × 2880@25/30fps
4K (16:9): 3840 × 2160@25/30fps
2.7K (4:3): 2688 × 2016@25/30fps
2.7K (16:9): 2688 × 1512@25/30fps
Does Osmo 360 support switching lenses during single-lens recording?
Yes. Osmo 360 allows you to switch between lenses during single-lens recording without interruptions. This feature supports recording specifications up to and including 4K/60fps.
Can Osmo 360 shoot slow-motion videos?
Yes. In Panoramic Video mode, it supports up to 4K/100fps 4x slow-motion panoramic videos, and in Single-Lens mode, it supports up to 4K/120fps 4x slow-motion flat videos.
How do I activate Osmo 360?
You can follow the steps below to activate the device:
1. Download the DJI Mimo App by scanning the QR code shown on the camera screen prompt or from an app store.
2. Press and hold the quick switch button to power on Osmo 360.
3. Launch the DJI Mimo App, tap the Camera icon, enable Bluetooth and Wi-Fi on your smartphone, and connect to Osmo 360.
4. After connecting Osmo 360 to the DJI Mimo App, you will be prompted to activate the device.
5. Complete the activation by following the prompts in the App.
Can I use Osmo 360's accessories with other Osmo series products?
Osmo 360 is compatible with Osmo Action Quick-Release accessories. For more details, please check the Osmo 360 Downloads page.
Can I mount third-party action camera accessories to Osmo 360?
Yes. You can mount third-party action camera accessories with the Quick-Release Adapter Mount.
Can the Osmo 360 Transparent Lens Protectors be used underwater?
No.
Osmo 360 Transparent Lens Protectors* are only splash-proof.
Before using the Osmo 360 Transparent Lens Protectors in non-underwater environments, please clean the area around the camera lens and the surface of the lens to ensure that both the lens and the mounting slot are free of fingerprints, oil stains, or other smudges. Any foreign matter on the inner/outer surface of the lens or the Protectors may affect image quality.
Avoid using the Osmo 360 Transparent Lens Protectors during water sports or in rainy or snowy conditions, as this may cause fogging. If fogging occurs on the inner side of the Protectors, please wipe it dry with a soft cloth before use.
When removing the Protectors, please be careful not to scratch the camera lens.
* Osmo 360 Transparent Lens Protectors are sold separately.
Is Osmo 360 waterproof?
Osmo 360 (camera body only) can be used at depths of up to 10 meters underwater.
Before use, please ensure the battery compartment cover and USB-C port cover are securely closed. It is not recommended to use the camera body only for long-term underwater shooting or in environments with high water impact pressure. Osmo 360 has an IP68 waterproof rating. Do not use the camera in hot springs or extreme underwater environments, or let it come into contact with corrosive or unknown liquids. The camera alone is waterproof to a depth of 10 meters, but due to the convex fisheye lens design, underwater light refraction may cause image distortion and stitching errors. Therefore, it is not recommended to bring the camera body only for underwater shooting.
What microSD cards does Osmo 360 support?
Recommended Models:
Kingston CANVAS Go! Plus 64GB U3 A2 V30 microSDXC
Kingston CANVAS Go! Plus 128GB U3 A2 V30 microSDXC
Kingston CANVAS Go! Plus 256GB U3 A2 V30 microSDXC
Kingston CANVAS Go! Plus 512GB U3 A2 V30 microSDXC
Kingston CANVAS Go! Plus 1TB U3 A2 V30 microSDXC
Lexar SILVER PLUS 64GB U3 A2 V30 microSDXC
Lexar SILVER PLUS 128GB U3 A2 V30 microSDXC
Lexar SILVER PLUS 256GB U3 A2 V30 microSDXC
Lexar SILVER PLUS 512GB U3 A2 V30 microSDXC
Lexar SILVER PLUS 1TB U3 A2 V30 microSDXC
1. When capturing 360° content, Osmo 360's CMOS sensor features an imaging area equivalent to that of a 1-inch CMOS sensor with a 4:3 aspect ratio.
2.Measured under laboratory conditions at 25° C (77° F), while recording 8K/30fps 360° video, with Wi-Fi off, Gesture Control off, Voice Control off, Editing Assistant off, and the screen off. Data was collected in a controlled environment and should be taken as reference only. When activating and using Osmo 360 in the EU and the UK, actual battery life may vary due to local regulations on product operating temperatures. Refer to the actual user experience.
3. Recommended for handheld use only. Do not use in environments with strong vibrations. For vehicle-mounted applications (e.g., motorcycles or cars), use the High-Strength Carbon Fiber Invisible Selfie Stick together with the appropriate stabilizing accessories.
4. When mounting on a vehicle for third-person perspective shots, always use it with the Dual Heavy-Duty Clamp and the High-Strength Carbon Fiber Invisible Selfie Stick.
5. "DJI's first" refers to Osmo 360 being DJI's first camera, as of its launch date on July 31, 2025, to feature two 4000 × 4000 square sensors capable of capturing native 8K 360° video with 2.4 μm large pixels.
6. Measured under laboratory conditions at 25° C (77° F), while recording 6K/24fps 360° video, with Endurance mode on, Wi-Fi off, Gesture Control off, Voice Control off, Editing Assistant off, and the screen off. Data was collected in a controlled environment and should be taken as reference only.
7. The Osmo 360 Standard Combo does not include an Invisible Selfie Stick, which can be purchased separately.
8. Direct connection to the first-generation DJI Mic is not supported. DJI microphones are sold separately.
