Osmo 70cm Invisible Selfie Stick
When used with Osmo 360, the selfie stick disappears from the shot, enabling a dramatic third-person perspective *. Its lightweight design folds down to palm size, making it easy to carry anywhere.
* Recommended for handheld use only. Do not use in environments with strong vibrations. For vehicle-mounted applications (e.g., motorcycles or cars), use the High-Strength Carbon Fiber Invisible Selfie Stick together with the appropriate stabilizing accessories.
Before storing the selfie stick, ensure that sand and other foreign objects are removed from the surface. If the selfie stick comes into contact with seawater, rinse it with fresh water and dry it thoroughly before storing.
Osmo 70cm Invisible Selfie Stick × 1
Dimensions (Folded): Approx. 181 mm in length, Approx. 24 mm in diameter
Dimensions (Unfolded): Length approx. 700 mm, diameter approx. 24 mm
Weight: Approx. 101 g
Osmo Nano
Osmo 360
