Osmo Action Adhesive Base Kit
The Quick-Release Adapter Mount has added a positioning clip to enhance the impact resistance. The Flat Adhesive Base features a large adhesive area with a strong connective force. With a large area of 3M tape at the bottom, the camera can be securely fixed to surfboards, snowboards, and other sporting equipment, making it suitable for a wide range of high-intensity scenarios.
In order to avoid risk of damage, do not throw, strike, or crush this product.
The ideal attachment temperature range for the Flat Adhesive Base is -10° to 40° C (14° to 104° F). Do not attach to curved surfaces, and make sure the attachment surface is clean. It is recommended to press down on the attachment for 10 seconds after applying and leave for 30 minutes before use.
Osmo Action Quick-Release Adapter Mount × 1
Osmo Locking Screw × 1
Osmo Flat Adhesive Base × 1
Dimensions: 40.2×21×34.2 mm
Weight: 16 g
Dimensions: 59.7 mm (diameter), 29.33 mm (height)
Weight: 20.7 g
Osmo Locking Screw
Weight: 11.2 g
Osmo 360 (Osmo Action Quick-Release Adapter Mount is required and sold separately)
Osmo Action 5 Pro
Osmo Action 4
Osmo Action 3
