Osmo Magnetic Ball-Joint Adapter Mount
Combines the 3M adhesive base with ball-joint design, allowing you to install the camera anywhere.* The lens orientation can be adjusted flexibly, the angles are fresh and diverse, and more accessories can be connected via the 1/4" threaded hole on the bottom.
* It is recommended to use this product in static scenarios. The ideal attachment temperature range of the base is -10° to 40° C (14° to 104° F). Do not attach to curved surfaces, and make sure the attachment surface is clean. It is recommended to press down on the attachment for 10 seconds after applying and leave for 30 minutes before use.
Osmo Magnetic Ball-Joint Adapter Mount × 1
Dimensions: 39.8×39.8×51.4 mm (L×W×H)
Weight: 49 g
Osmo Action 4
Osmo Action 3
DJI Action 2
