Osmo Action 3 Diving Combo
Select Combo
Don't Miss Top Accessories
Capture Everything Stably
Action 3 adopts DJI's next generation of intelligent stabilization algorithm. Even if the camera rotates 360°, images stay stable horizontally.
Ultra HD with Super-Wide FOV
A 155° super-wide distortion-free FOV combined with 4K/120fps [1] makes all of your dynamic moments look natural, clear, and super smooth.
150 Mins in -20° C (-4° F)
Action 3 delivers a 160-min max operating time [2] and a 150-min max in -20° C (-4° F) temps [3] for powerful winter-weather performance.
Quick-Release Vertical Mount
A quick-release design allows fast switches to vertical shooting plus impact resistance with strong magnetic force and a positioning notch. [4]
Enhanced Waterproof Capability
The camera body is tough, fully optimized, and waterproof. You can use it down to 16 meters [5] without the need for any additional accessories.
4K HDR Video, 1 Billion Colors
HDR video delivers vivid yet natural details, even in high-contrast scenarios, and 10-bit color depth captures over one billion colors.
Osmo Action 3
Osmo Action 3 Extreme Battery
Osmo Action 3 Horizontal-Vertical Protective Frame
Osmo Action 3 Rubber Lens Protector
× 2
Osmo Action 3 Quick-Release Adapter Mount
Osmo Flat Adhesive Base
Osmo Locking Screw
Type-C to Type-C PD Cable
DJI Logo Sticker
× 2
How is the stabilization performance of Osmo Action 3? Compared with the previous generation, what improvements does it have?
Osmo Action 3 is equipped with a more comprehensive stabilization system, which provides three stabilization modes to choose from. RockSteady 3.0 adopts a new generation of intelligent stabilization algorithm, which can effectively eliminate camera shake in all directions. It supports recording up to 4K/120fps videos from a stable and immersive first-person perspective. HorizonSteady not only effectively eliminates camera shake in all directions, but also horizontally corrects tilt at any angle, so that the footage can remain horizontally stable, even through heavy bumps and 360° rotations. In addition, you can activate HorizonBalancing, which corrects the tilt horizontally within ±45° and supports recording stable 4K/60fps HD videos.
How is the waterproof performance of Osmo Action 3? Compared with the previous generation, what improvements does it have?
Osmo Action 3 can be used at depths of up to 16 meters, and up to 60 meters when used with the Waterproof Case, meeting the shooting needs of most underwater scenarios.
How is the operating time of Osmo Action 3?
Osmo Action 3 features excellent operating time [6] in both room-temperature and cold environments.
In 25° C (77° F) environments:
When recording 1080p/30fps video, the max operating time is 160 minutes.
When recording 1080p/60fps video, the max operating time is 124 minutes.
When recording 4K/120fps video, the max operating time is 31 minutes.
In -20° C (-4° F) environments:
When recording 1080p/30fps video, the max operating time is 150 minutes.
When recording 1080p/60fps video, the max operating time is 117 minutes.
When recording 4K/120fps video, the max operating time is 65 minutes.
Does Osmo Action 3 support fast charging?
Yes. You can use the DJI 30W USB-C Charger [7] to fast charge Osmo Action 3. A single battery can be charged to 80% in 18 minutes, and can be fully charged in 49 minutes. [8] With the Multifunctional Battery Case, three batteries can be fast charged intelligently, making shooting more efficient.
What other accessories for Osmo Action 3 are worth buying? Can I mount previous-generation product accessories or third-party camera accessories to Osmo Action 3?
In addition to the accessories included in the Standard Combo, useful accessories for Osmo Action 3 also include the Osmo Action 3 Multifunctional Battery Case, Osmo 1.5m Extension Rod, Osmo Action 3 Waterproof Case, Osmo Action Biking Accessory Kit, Osmo Action Diving Accessory Kit, and more, allowing you to master shooting for daily creation and various extreme sports such as biking, skiing/snowboarding, and diving. Osmo Action 3 is compatible with previous-generation accessories such as the DJI Magnetic Ball-Joint Adapter Mount, DJI Floating Handle, and Osmo Action Mounting Kit. You can also mount third-party action camera accessories via the Quick-Release Adapter Mount, for an expanded range of dynamic shooting options.
What is LightCut? What features are supported when Osmo Action 3 is connected to LightCut?
LightCut is a video editing app officially recommended by DJI. Its shooting and editing functions fit the usage scenarios of DJI users. After connecting with the camera, LightCut can provide quick and convenient footage previews without the need for exporting footage. It provides an AI-based one-tap editing function, diverse exclusive video templates, shooting tutorials, and other resources for you to edit and generate videos effortlessly, making it a reliable shooting and editing tool for DJI users.
How strong is the magnetic connection between Osmo Action 3 and the accessories?
Osmo Action 3 adopts a new quick-release design, which greatly enhances the impact resistance by strengthening the magnetic force and adding a positioning clip. As a result, the camera can be firmly connected to various common accessories, making it suitable for multiple high-intensity sports scenarios. [4]
What microSD cards does Osmo Action 3 support?
Recommended models:
SanDisk Extreme 32GB V30 A2 UHS-I Speed Grade 3
What resolution settings does Osmo Action 3 support?
Osmo Action 3 supports the following resolution settings:
4K (4:3): 4096×3072@24/25/30/48/50/60fps
What upgrades does the firmware update of Osmo Action 3 have?
This firmware update has the following main upgrades:
1. 4K HDR Video
The camera adopts a chip-level HDR technology and supports recording HDR video at 4K/2.7K/1080p@24/25/30fps (16:9) . Even in high-contrast scenarios, like sunsets and sunrises, it can restore highlight and shadow details, allowing you to capture images with natural lighting transitions. At the same time, you can enable RockSteady 3.0, RockSteady+, HorizonSteady, or HorizonBalancing to stabilize image details in motion.
2. 10-Bit Color Depth
Over one billion colors can be recorded to reproduce your world in stunning detail, delivering smoother and more natural color gradations for greater flexibility in post-production.
3. Timecode
Timecode is designed for multi-camera shooting. After synchronizing the timecode of each camera, you can quickly align materials from different cameras with the built-in timecode information, greatly enhancing the post-production efficiency.
Does Osmo Action 3 support the Osmo Action Extreme Battery Plus (1950 mAh)?
Yes. Please update the firmware before using this battery.
1. The 120fps high frame rate is applicable to 1080p, 2.7K 16:9, and 4K 16:9 video specifications.
2. Tested in a 25° C (77° F) laboratory environment while recording 1080p/30fps video with EIS disabled and both screens off, and should be used for reference only.
3. Tested in a -20° C (-4° F) laboratory environment while recording 1080p/30fps video with EIS disabled and both screens off, and should be used for reference only.
4. In order to avoid damage, do not strike, crush, or drop this product.
5. Before use, please close the battery cover and the port cover, and also tighten the Lens Protective Cover. It is recommended to install the waterproof case for long-term underwater shooting or when shooting in environments with high pressure or water impacts. Osmo Action 3 and its Waterproof Case have an IP68 waterproof rating. Do not use the camera in hot springs or expose it to corrosive liquids.
6. Tested in a laboratory environment with different video specifications, EIS disabled, and screens off, and should be used for reference only. The operating time of the 4K/120fps specification is not the battery exhaustion time. The actual operating time is related to ambient temperature and other factors.
7. The DJI 30W USB-C Charger is sold separately.
8. Tested in a 25° C (77° F) laboratory environment while using the DJI 30W USB-C Charger with the photo taking/video recording function disabled and the screens off. Should be used for reference only.
