Osmo Action 3
Supports up to 160 minutes* of battery life. Supports continuous recording for up to 150 minutes** in temperatures as low as -20° C (-4° F). Supports PD fast charging to power up to 80% in just 18 minutes.***
* Tested in a 25° C (77° F) laboratory environment while recording 1080p/30fps video with EIS disabled and the screens off, and should be used for reference only.
** Tested in a -20° C (-4° F) laboratory environment while recording 1080p/30fps video with EIS disabled and the screens off, and should be used for reference only.
*** Tested in a 25° C (77° F) laboratory environment while using the DJI 30W USB-C Charger with the photo taking/video recording function disabled and the screens off. Should be used for reference only.
Osmo Action Extreme Battery × 1
Capacity: 1770 mAh
Operating Temperature: -20° to 45° C (-4° to 113° F)
Dimensions: 44.2×34.4×12.1 mm (L×W×H)
Weight: 34 g
Osmo 360
Osmo Action 6
Osmo Action 5 Pro
Osmo Action 4
Osmo Action 3
