bannerimg
Deliver to
Out of Stock
USD $238
Out of Stock
Osmo Action 3
  • Capture Everything Stably
    Action 3 adopts DJI's next generation of intelligent stabilization algorithm. Even if the camera rotates 360°, images stay stable horizontally.
  • Ultra HD with Super-Wide FOV
    A 155° super-wide distortion-free FOV combined with 4K/120fps [1] makes all of your dynamic moments look natural, clear, and super smooth.
  • 150 Mins in -20° C (-4° F)
    Action 3 delivers a 160-min max operating time [2] and a 150-min max in -20° C (-4° F) temps [3] for powerful winter-weather performance.
  • Quick-Release Vertical Mount
    A quick-release design allows fast switches to vertical shooting plus impact resistance with strong magnetic force and a positioning notch. [4]
  • Enhanced Waterproof Capability
    The camera body is tough, fully optimized, and waterproof. You can use it down to 16 meters [5] without the need for any additional accessories.
  • 4K HDR Video, 1 Billion Colors
    HDR video delivers vivid yet natural details, even in high-contrast scenarios, and 10-bit color depth captures over one billion colors.
  • Osmo Action 3
    Osmo Action 3
  • Osmo Action 3 Extreme Battery
  • Osmo Action 3 Horizontal-Vertical Protective Frame
  • Osmo Action 3 Rubber Lens Protector
    × 2
  • Osmo Action 3 Quick-Release Adapter Mount
    × 2
  • Osmo Flat Adhesive Base
  • Osmo Locking Screw
    Osmo Locking Screw
    × 2
  • Type-C to Type-C PD Cable
  • DJI Logo Sticker
    DJI Logo Sticker
    × 2
  • Osmo Action 3 1.5m Extension Rod
* The extension rod length has a tolerance, with an acceptable deviation range of ±5% (±7.5 cm).
1. The 120fps high frame rate is applicable to 1080p, 2.7K 16:9, and 4K 16:9 video specifications.
2. Tested in a 25° C (77° F) laboratory environment while recording 1080p/30fps video with EIS disabled and both screens off, and should be used for reference only.
3. Tested in a -20° C (-4° F) laboratory environment while recording 1080p/30fps video with EIS disabled and both screens off, and should be used for reference only.
4. In order to avoid damage, do not strike, crush, or drop this product.
5. Before use, please close the battery cover and the port cover, and also tighten the Lens Protective Cover. It is recommended to install the waterproof case for long-term underwater shooting or when shooting in environments with high pressure or water impacts. Osmo Action 3 and its Waterproof Case have an IP68 waterproof rating. Do not use the camera in hot springs or expose it to corrosive liquids.
6. Tested in a laboratory environment with different video specifications, EIS disabled, and screens off, and should be used for reference only. The operating time of the 4K/120fps specification is not the battery exhaustion time. The actual operating time is related to ambient temperature and other factors.
7. The DJI 30W USB-C Charger is sold separately.
8. Tested in a 25° C (77° F) laboratory environment while using the DJI 30W USB-C Charger with the photo taking/video recording function disabled and the screens off. Should be used for reference only.
We Value Your Privacy
Cookie Preferences
