Osmo Action 3 Standard Combo (Refurbished Unit)
Select Combo
Don't Miss Top Accessories
Capture Everything Stably
Action 3 adopts DJI's next generation of intelligent stabilization algorithm. Even if the camera rotates 360°, images stay stable horizontally.
Ultra HD with Super-Wide FOV
A 155° super-wide distortion-free FOV combined with 4K/120fps [1] makes all of your dynamic moments look natural, clear, and super smooth.
150 Mins in -20° C (-4° F)
Action 3 delivers a 160-min max operating time [2] and a 150-min max in -20° C (-4° F) temps [3] for powerful winter-weather performance.
Quick-Release Vertical Mount
A quick-release design allows fast switches to vertical shooting plus impact resistance with strong magnetic force and a positioning notch. [4]
Enhanced Waterproof Capability
The camera body is tough, fully optimized, and waterproof. You can use it down to 16 meters [5] without the need for any additional accessories.
4K HDR Video, 1 Billion Colors
HDR video delivers vivid yet natural details, even in high-contrast scenarios, and 10-bit color depth captures over one billion colors.
Osmo Action 3
Osmo Action 3 Extreme Battery
Osmo Action 3 Horizontal-Vertical Protective Frame
Osmo Action 3 Rubber Lens Protector
× 2
Osmo Action 3 Quick-Release Adapter Mount
Osmo Flat Adhesive Base
Osmo Locking Screw
Type-C to Type-C PD Cable
DJI Logo Sticker
× 2
1. The 120fps high frame rate is applicable to 1080p, 2.7K 16:9, and 4K 16:9 video specifications.
2. Tested in a 25° C (77° F) laboratory environment while recording 1080p/30fps video with EIS disabled and both screens off, and should be used for reference only.
3. Tested in a -20° C (-4° F) laboratory environment while recording 1080p/30fps video with EIS disabled and both screens off, and should be used for reference only.
4. In order to avoid damage, do not strike, crush, or drop this product.
5. Before use, please close the battery cover and the port cover, and also tighten the Lens Protective Cover. It is recommended to install the waterproof case for long-term underwater shooting or when shooting in environments with high pressure or water impacts. Osmo Action 3 and its Waterproof Case have an IP68 waterproof rating. Do not use the camera in hot springs or expose it to corrosive liquids.
