Osmo Action 3 Waterproof Case
Provides waterproof protection at depths of up to 60 meters,* giving divers more freedom to explore and capture. Uses high-strength glass for a more clear and confident viewing experience.
* Before use, close the battery compartment cover and the USB-C port cover, and tighten the Lens Protective Cover. It is recommended to install the Waterproof Case for long-duration underwater shooting or in environments with high water impact pressure. The Osmo Action 3 Waterproof Case has an IP68 waterproof rating. Do not use the camera in hot springs or expose it to corrosive liquids.
Osmo Action 3 Waterproof Case × 1
Anti-Fog Inserts × 3
Dimensions: 87.4×42.8×79.4 mm (L×W×H)
Weight: 104 g
Anti-Fog Inserts
Dimensions: 24×22.5×3.2 mm (L×W×H)
Weight: 2 g
Osmo Action 3
