Osmo Action 4 Standard Combo
- 1/1.3″ Sensor & Low-Light Imaging
- 10-bit & D-Log M Color Performance
- Deep-Freeze Resistant & Long-Lasting Battery Life
- 4K/120fps & 155º Ultra-Wide FOV
- Magnetic Quick Release & Native Vertical Video
- 360° HorizonSteady
- Waterproof up to 18m
- Dual Full-Color Touchscreens
Select Option
1/1.3-inch Image Sensor
10-bit & D-Log M Peformance
Packed with Peformance
360° HorizonSteady
Extensive Accessories
Osmo Action 4
Osmo Action Extreme Battery
Osmo Locking Screw
Type-C to Type-C PD Cable
Osmo Action Lens Hood
Osmo Action Anti-Slip Pad
DJI Logo Sticker
Moments By You
From USD $399
From USD $329
From USD $239
HorizonSteady
HorizonSteady
HorizonSteady
What improvements does Osmo Action 4 have in terms of image quality? What are its advantages in low-light recording?
Osmo Action 4 has a larger 1/1.3-inch image sensor than its predecessor. With a single pixel equivalent size of 2.4μm, Osmo Action 4 delivers footage with minimal noise in both moving and low-light scenes.
D-Log M is designed for professional videography. It enhances the dynamic range in high-contrast or multi-colored environments (such as blooming gardens). It enables greater flexibility in color grading during post-editing, capturing the scene's essence. 10-bit color depth enables smoother color transition with no discrete step changes.
The 155° ultra wide-angle also captures an expansive view of your surroundings during movement, creating an intense visual impact and immersing you in vast landscapes when recording scenery.
What is D-Log M of Osmo Action 4's color mode?
It is designed to capture a wide dynamic range from the sensor, and colors are distributed evenly so the bright and dark parts of the video have greater fidelity and clarity. It is not a LUT, but a lower-contrast video with a flat color profile, which is great for expanding post-processing options.
What resolution settings does Osmo Action 4 support?
Osmo Action 4 supports the following resolution settings:
What video and stabilization specifications does auto low-light image enhancement support?
When Low-Light Image Enhancement is set to Auto, it supports all stabilization options for 1080p@24/25/30fps, 2.7K (16:9 or 4:3) @24/25/30fps, and RockSteady for 4K (16:9) @24/25/30fps.
What additional accessories are included in the Adventure Combo compared to the Standard Combo? Is it worth buying?
Compared to the Standard Combo, the Osmo Action 4 Adventure Combo comes with an additional two Extreme Batteries and a 1.5m Extension Rod, providing you with ample power for long-duration shoots and allowing for multi-angle selfies during skiing or other scenarios.
Is Osmo Acion 4 compatible with accessories of the last-generation product?
Osmo Action 4 is compatible with most accessories of its predecessor, such as:
Osmo Action 1.5m Extension Rod Kit
Osmo Action Biking Accessory Kit
Osmo Action Multifunctional Battery Case
Osmo Action 60m Waterproof Case
Osmo Action Adhesive Base Kit
Osmo Magnetic Ball-Joint Adapter Mount
Osmo Action Chest Strap Mount
Osmo Action Suction Cup Mount
Osmo Action Helmet Chin Mount
Osmo Action Handlebar Mount
Osmo Action Surfing Tether
DJI Floating Handle
Osmo Backpack Strap Mount
Osmo Action ND Filters Set
Osmo Action Bike Seat Rail Mount
Osmo Action Curved Adhesive Base Kit
Osmo Action Mini Extension Rod
Osmo Action 360° Wrist Strap
Osmo Action Mini Handlebar Mount
Check the Osmo Action 4 accessory compatibility page for more details. Additionally, there are new Osmo Action 4 accessories, including the Osmo Action Bite Mount, Osmo Action GPS Bluetooth Remote Controller, and the Osmo Action Road Cycling Accessory Kit.
Can I mount third-party action camera accessories to Osmo Action 4?
Yes. You can mount third-party action camera accessories with the quick-release adapter mount.
What is RockSteady 3.0?
Osmo Action 4 uses RockSteady 3.0 technology to stabilize footage. This Electronic Image Stabilization (EIS) technology is realized by increasing the shutter speed, analyzing the images captured by the CMOS sensor, and compensating by cutting off the edges of these images. In this way, multiple frames are overlaid and finally combined into a single frame that is sharp, clear, and accurately exposed.
What is HorizonSteady?
Does Osmo Action 4 support fast charging?
Yes. You can use the DJI 30W USB-C Charger* to fast charge Osmo Action 4.
* The DJI 30W USB-C Charger is sold separately.
What microSD cards does Osmo Action 4 support?
Recommended models:
