bannerimg
Deliver to
Estimated shipping date: Apr. 24, expected arrival date: Apr. 28
USD $328
Osmo Action 4
  • 1/1.3-inch Image Sensor
  • 10-bit & D-Log M Peformance
  • Packed with Peformance
  • 360° HorizonSteady
  • Extensive Accessories
  • DJI OsmoAudio™
  • Osmo Action 4
    Osmo Action 4
  • Osmo Action Extreme Battery
  • Osmo Action Surfing Tethers Kit
  • Osmo Locking Screw
    Osmo Locking Screw
  • Type-C to Type-C PD Cable
  • Osmo Action Lens Hood
  • Osmo Action Anti-Slip Pad
  • DJI Logo Sticker
    DJI Logo Sticker
Moments By You
Osmo Action 4
Osmo Action 3
DJI Action 2
Osmo Action 4 Standard Combo
Osmo Action 3 Standard Combo
DJI Action 2 Dual-Screen Combo (32GB)
Osmo Action 4
Osmo Action 3
DJI Action 2
Cold-Resistant and Durable Action Camera
Magnetic Wearable Action Camera
From USD $299
From USD $169
From USD $229
Imaging Performance
img1/1.3″ CMOS
img1/1.7″ CMOS
img1/1.7″ CMOS
2.4 μmEquivalent Pixel Size
1.6 μmEquivalent Pixel Size
imgMax Video Resolution
imgColor Performance
D-Log MColor Mode
D-CinelikeColor Mode
Stabilization
imgRockSteady 3.0/3.0+
HorizonSteady, HorizonBalancing
imgRockSteady 2.0
HorizonSteady
Main Body
160 minsMax Operating Time
70 minsMax Operating Time
18 mCaseless Waterproof
16 mCaseless Waterproof
10 mCaseless Waterproof
-20° to 45° C (-4° to 113° F)Operating Temperature
0° to 40° C (32° to 104° F)Operating Temperature
SupportedFast Charging
Not SupportedFast Charging
5. Sold separately.
We Value Your Privacy
Cookie Preferences
