Osmo Action 4
  • 1/1.3-inch Image Sensor
  • 10-bit & D-Log M Peformance
  • Packed with Peformance
  • 360° HorizonSteady
  • Extensive Accessories
  • DJI OsmoAudio™
  • Osmo Action 4
    Osmo Action 4
  • DJI Mic Mini Transmitter (Infinity Black)
  • Osmo Action Extreme Battery
  • Osmo Action Mini Extension Rod
  • DJI Mic Mini Transmitter Charging Dock (Infinity Black)
  • DJI Mic Mini Windscreen (Black/Gray)
  • DJI Mic Mini Windscreen (Black)
  • DJI Mic Mini Clip Magnet
  • DJI Mic Mini Compact Carrying Pouch
  • Osmo Locking Screw
    Osmo Locking Screw
  • Type-C to Type-C PD Cable
  • Osmo Action Lens Hood
  • Osmo Action Anti-Slip Pad
Moments By You
5. Sold separately.
