dji.comFree shipping on orders over USD $149.
The retractable Osmo Action Extension Rod can reach a maximum length of 908 mm, allowing you to shoot from more angles. The universal interface on the top is compatible with more action cameras, with an adjustable pitch of up to 90°. A built-in phone clamp is convenient for switching and rotating your phone for more shooting angles, and even allows control of Osmo Action for shooting, recording, and switching between the front and back screens. A standard 1/4-inch mount at the bottom can be connected with a tripod. You can also fix the phone clamp on the top of the device and use it as a selfie stick.
Highlights
Increased field of view and an adjustable pitch of up to 90° to meet different shooting needs.
Built-in phone clamp for remote control over the Osmo Action with your phone.
Can also be used as a selfie stick.
Tips
The rod needs to be locked by twisting before use.
Clean and dry the extension rod carefully if it is exposed to water or foreign elements as this may affect product performance.
Osmo Action Extension Rod × 1
Lock Screw × 2
Phone Clamp × 1
Strap × 1
Size: 241×52×72 mm (folded)
908×52×72 mm (unfolded)
Weight: 236.5 g
Got questions?Let us help you.
