Osmo Action Mounting Kit
Made of SUS 303 stainless steel, this accessory is corrosion-resistant, sturdy, and durable, allowing you to mount the camera to a variety of locations. The pivot arm allows you to turn the camera's mounting position 90° for expanded shooting options. These convenient mounts enable you to attach the camera to a wide variety of sporting equipment such as skateboards, bikes, helmets, and more.
High-quality and durable accessory that mounts to a variety of platforms.
Turns DJI Action 2 or Osmo Action's mounted position 90°.
Attach DJI Action 2 or Osmo Action to flat or curved surfaces for expanded shooting options.
Osmo Action Pivot Arm × 1
Osmo Action 1/4-inch Screw Adapter × 1
Osmo Action Locking Screw × 3
Osmo Action Quick-Release Base × 1
Osmo Action Flat Adhesive Mount × 1
Osmo Action Curved Adhesive Mount × 1
Dimensions: 13.3×15.7×46.1 mm
Weight: 8.3 g
Dimensions: 29.6×29.6×26.8 mm
Weight: 10.0 g
Dimensions: 23×13×55 mm
Weight: 11.3 g
Diameter × Height: 35×26 mm
Weight: 10.5 g
Diameter × Height: 42.5×12.5 mm
Weight: 8.8 g
Dimensions: 42×27×13 mm
Weight: 11.2 g
Osmo Action 3
DJI Action 2
