Featuring a magnetic quick-release design, this mount ensures a secure and reliable connection with the camera. It is compatible with 1/4" threaded invisible selfie sticks for easy installation*. The adjustable tilt makes it easy to fine-tune the camera angle for more accurate single-lens framing.
* The Osmo 360 Standard Combo does not include an Invisible Selfie Stick, which can be purchased separately.
Tips
1. When using the invisible selfie stick feature, adjust the adapter to the 0° position to ensure the selfie stick and camera are aligned in the horizontal direction.
2. When using with other 1/4" accessories, be sure to tighten the threads to prevent accessories from loosening or falling due to vibration.
Osmo Adjustable Quick-Release Adapter Mount × 1
Dimensions: Approx. 41 × 22 × 32 mm (L × W × H)
Weight: Approx. 27 g
Joint Angle (two stops): 0°, 68°
Osmo 360
