Osmo Mobile 7P Vlog Combo (DJI Mic Mini Transmitter Infinity Black)
Select Option
Native Tracking & Versatile Functionality [1]
The new Multifunctional Module [2] enables subject tracking without DJI Mimo and offers audio reception and lighting for full creative support.
Robust 3-Axis Gimbal Stabilization
Featuring DJI's 7th-gen stabilization, the Osmo Mobile 7 Series works with most smartphones [3] to deliver smooth, shake-free shots every time.
Quick Unfold, Quick Launch
Unfold the gimbal to power it on. Easily mount a paired phone with the magnetic design, and DJI Mimo pops up automatically [4] for quick filming.
Built-in Extension Rod & Tripod
Osmo Mobile 7P's built-in extension rod and tripod [5] offer versatile angles without extra gear, ensuring effortless solo creation and storage.
Easy Tutorials & One-Tap Editing
Effortlessly capture and edit using the Mimo app. With ShotGuides and One-Tap Edit, gain smart scene insights and create stunning videos swiftly.
10-Hour Battery Life & Phone Charging
The Osmo Mobile 7 Series offers 10-hour operation [6] and a USB-C port for phone charging, ideal for extended outdoor filming and live streaming.
Osmo Mobile 7P
DJI OM 7 Series Magnetic Phone Clamp
DJI OM Multifunctional Module
Power Cable (USB-C to USB-C, 50 cm)
Phone Charging/Audio Recording Cable (USB-C to USB-C, 15 cm)
Storage Pouch
DJI Mic Mini Transmitter (Infinity Black)
DJI Mic Mini Windscreen (Black)
DJI Mic Mini Transmitter Charging Dock (Infinity Black)
DJI Mic Mini Clip Magnet
DJI Mic USB-C Charging Cable
Moments by You
* ActiveTrack 7.0 is only available within the DJI Mimo app. Dual Lens Boost is available only on iPhone 13 Pro, iPhone 13 Pro Max, and later Pro/Pro Max models (running iOS 16 or higher), and works within a 1x to 8x zoom range.
What improvements does Osmo Mobile 7P offer compared with Osmo Mobile 6?
Osmo Mobile 7P has been upgraded in several areas, including the following:
1. It comes with a Multifunctional Module that supports intelligent tracking, DJI Mic Mini reception, and lighting features.
2. It integrates a built-in tripod and extension rod, enabling more flexible and convenient shooting.
3. It offers quick setup, allowing you to unfold it in one motion and begin filming immediately. After powering off, it automatically returns to a pre-folded position for easy storage.
4. It can work with the Multifunctional Module to enable versatile intelligent tracking, allowing seamless use with your smartphone's native camera app or third-party camera/live streaming apps.
5. It allows you to easily adjust the brightness and color temperature of the fill light using the side wheel.
6. It now provides up to 10 hours* of operating time and features the ability to charge your smartphone.
7. The enhanced magnetic phone clamp provides a more secure connection, even for larger smartphones.
* Measured with the gimbal balanced in a level and stationary state without additional accessories.
What improvements does Osmo Mobile 7 offer compared with Osmo Mobile 6?
Osmo Mobile 7 has been upgraded in several areas, including the following:
1. It offers an optional Multifunctional Module with intelligent tracking, DJI Mic Mini reception, and lighting features.
2. It integrates a built-in tripod, enabling more flexible and convenient shooting.
5. It now provides up to 10 hours* of operating time and features the ability to charge your smartphone.
6. The enhanced magnetic phone clamp provides a more secure connection, even for larger smartphones.
What improvements does ActiveTrack 7.0 have compared with the previous version?
ActiveTrack 7.0 offers significant upgrades in its basic tracking functionality:
1. Excellent Composition: It securely locks onto the subject based on the default position (center of the frame) or a user-defined composition.
2. Stable Capture: In multi-person scenarios, even if the subject briefly leaves the frame, it can quickly and accurately be re-acquired upon re-entering.
3. Smooth Tracking: Whether following objects or pets (like cats and dogs), as long as their basic appearances remain unchanged, tracking remains smooth.
4. Outstanding Result Quality: During the tracking process, zoom functionality is supported without losing track of the subject, ensuring naturally fluid final results.
5. Smart Capture: In multi-subject scenarios, the DJI Mimo app interface intelligently displays multiple detection boxes, and tapping a detection box can trigger ActiveTrack. You can also quickly switch between subjects by tapping different detection boxes.
Which smartphones are compatible?
The Osmo Mobile 7 Series is compatible with most smartphones on the market. It is recommended to use smartphones with a width of 67-84 mm, thickness of 6.9-10 mm, and weight of 170-300 g.
Please visit the official DJI website for the full smartphone compatibility list.
What is the magnetic force?
The magnetic force of the Osmo Mobile 7 Series is approximately 40 Newtons, which is strong enough to hold an object equivalent to the weight of two 2-liter soda bottles. This ensures a secure attachment for smartphones.
Will the magnetic feature interfere with or affect my smartphone or other items?
The Osmo Mobile 7 Series uses a special closed-loop magnetic design that does not affect the performance of the attached smartphone. However, some smartphones may prompt for calibration due to the compass orientation after mounting. Simply follow the on-screen instructions on your smartphone for calibration to resume normal use.
The magnetic design may influence other magnetic-sensitive products. Do not place the Osmo Mobile 7 Series near bank cards, pacemakers, RAM chips, hard drives, and similar items.
Does the gimbal require balancing before use?
No. Due to its powerful motors, accurate balancing is not needed for the Osmo Mobile 7 Series. When using the magnetic phone clamp, simply attach it approximately to the middle of the smartphone.
Can I use the magnetic phone clamp with my phone case on?
Yes, as long as the combined thickness of the smartphone and the case does not exceed 10 mm.
What scenarios are suitable for using the built-in tripod?
The built-in tripod is suitable for stable, level surfaces in windless environments. In other conditions, it is recommended to attach the DJI OM Grip Tripod to the bottom of the gimbal. The DJI OM Grip Tripod is sold separately.
What is the size of the mounting hole at the bottom of the gimbal?
The mounting hole at the bottom of the Osmo Mobile 7 Series is the standard 1/4"-20 UNC port, which is compatible with most tripods.
Can I use Glamour Effects for both photos and videos?
Yes. Glamour Effects are supported for taking photos (single and timed) and videos of common specifications. Some smartphones support shooting 1080p or 720p videos with Glamour Effects enabled.
In which apps can the Multifunctional Module enable intelligent tracking?
The Multifunctional Module allows intelligent tracking in the following apps:
1. Your smartphone's native camera app, including features like Cinematic mode on iPhones.
2. Live streaming platforms such as TikTok, Facebook, and Instagram.
3. Voice calls and video conferences.
4. Professional camera apps, including Blackmagic Camera and Protake.
Which microphone models are compatible with the audio recording feature?
The DJI Mic Mini Transmitter. Buy Now
Where can I find the Osmo Mobile 7/Osmo Mobile 7P user guide?
We recommend checking out the beginner's guide to Osmo Mobile 7/Osmo Mobile 7P, which includes tutorial videos, user manual, and comprehensive instructions covering unboxing, setup, activation, and device connection.
1. The DJI OM Multifunctional Module is required to enable tracking, audio reception (compatible with the DJI Mic Mini Transmitter), and lighting features, and it only supports tracking human subjects.
2. Osmo Mobile 7P comes with this module. Osmo Mobile 7 users will need to purchase the DJI OM 7 Series Tracking Kit separately to get the related accessories.
3. For more information, check the Smartphone Compatibility List on the official DJI website.
4. Auto pop-ups in the DJI Mimo app are only supported on iPhone and may vary based on actual conditions. For first-time use, complete device pairing, enable Quick Launch in the app, and follow the instructions to complete authorization.
5. The built-in tripod is suitable for stable, level surfaces in windless environments.
6. Measured with the gimbal balanced in a level and stationary state without additional accessories.
