Deliver to
Estimated shipping date: Apr. 23, expected arrival date: Apr. 29
USD $55
DJI Pocket 2
Waterproof at up to 60 m, the DJI Pocket 2 Waterproof Case enables Pocket 2 to capture high-quality under-water images that are glare and distortion-free. The internal clamp keeps the gimbal in place. The shutter/record Button and two mounting brackets on the outer surface further improve shooting experience.
Highlights
Two mounting brackets for more scenarios
Tips
Please check that DJI Pocket 2 is powered off before placing it into the waterproof case, and
make sure the securing ring is completely tightened. DJI takes no responsibility for any damage or loss resulting from improper use of DJI Pocket 2 underwater.
The camera cannot be adjusted when using the waterproof case.
Make sure the anti-fog insert works properly. Replace the anti-fog insert regularly.
Clean the waterproof case after using. Make sure the waterproof case is clean at all times.
DJI Pocket 2 Waterproof Case × 1
Anti-fog Insert × 3
Osmo Pocket Compatibility Pad × 1
Dimensions: 72.6×81.6×169.9 mm
Weight: 112.6 g
Max Depth of Usage under Water: 60 m
DJI Pocket 2
We Value Your Privacy
Cookie Preferences
