  • Chassis Front Armor
  • Mecanum Wheel Mounting Plate
  • Mecanum Wheel Damping Ring
    × 4
  • Mecanum Wheel Roller
    × 48
  • Grease
  • Motion Controller
  • Bottled Gel Beads
  • Screwdriver Handle
  • M3508I Brushless Motor and ESC
    × 4
  • Motor Mounting Plate
    × 4
  • Screw Box
  • Safety Goggles
  • X-Shaped Front Shaft Cover
  • Cable Retainer
  • Intelligent Battery Charger
  • AC Power Cable
  • Left-Threaded Inner Hub
    × 2
  • Left-Threaded Outer Hub
    × 2
  • Right-Threaded Inner Hub
    × 2
  • Right-Threaded Outer Hub
    × 2
  • Damping Ring Bracket
    × 4
  • Chassis Cabin Cover
  • Masking Tape
  • Vision Marker
    × 7
  • Chassis Cover
  • Chassis Middle Frame
  • Intelligent Controller
  • Front Axle Cover
  • Front Axle Module Base
  • Gimbal
  • Camera
  • Blaster
  • Gel Bead Container
  • Speaker
  • Hit Detector
    × 4
  • Camera Cable
  • Data Cables (35 cm)
  • Data Cables (23 cm)
    × 2
  • Data Cables (12 cm)
    × 4
  • Chassis Rear Armor
  • Chassis Left Armor
  • Chassis Right Armor
