RoboMaster S1
The PlayMore Kit includes one Gamepad, one Intelligent Battery, one Gel Bead Container, and one Bottle of Gel Beads, allowing you to make the most of your RoboMaster S1.
Gamepad: Specially designed for the RoboMaster S1, this allows users to connect the S1 with a mobile device and use control sticks and physical buttons for launching and custom skills, enhancing the control experience during gameplay.
Intelligent Battery: The 4.2 V high-voltage battery was specially designed for the RoboMaster S1. It uses three high-energy lithium-ion cells, and has a rated capacity of up to 25.92 Wh, providing a 35-minute operation time and a 100-minute standby time.
Gel Bead Container: Capable of holding approximately 430 gel beads.
Bottle of Gel Beads: Made of sodium polyacrylate, safe and non-toxic. It is recommended to use pure water to soak the gel beads at room temperature for three to four hours. Each bottle contains about 10,000 gel beads.
* Tested at a constant driving speed of 2.0m/s on flat surfaces.
Highlights
Dedicated gamepad for enhanced gameplay experience.
Essential accessories for endless fun.
Tips
Only use standard DJI Gel Beads to ensure ideal launching effects.
Gamepad × 1
Intelligent Battery × 1
Gel Bead Container × 1
Bottle of Gel Beads × 1
Micro USB Cable × 1
RoboMaster S1
