dji.comBuying GuidesRefurbished ProductsFree shipping on orders over USD $149.
  • Gimbal
  • BG30 Grip
  • Lens-Fastening Strap
  • Extended Grip/Tripod (Metal)
  • Quick-Release Plate (Arca-Swiss/Manfrotto)
  • Briefcase Handle
  • Camera Riser
  • Carrying Case
  • Multi-Camera Control Cable (USB-C, 30 cm)
  • Multi-Camera Control Cable (Sony Multi, 30 cm)
  • Multi-Camera Control Cable (Micro-USB, 30 cm)
  • Multi-Camera Control Cable (Mini-USB, 30 cm)
  • Hook-and-Loop Strap
    × 3
  • D-Ring Camera Mounting Screw 1/4"-20
    × 2
  • RSA/NATO Port Cover
  • Pan Axis Sleeve
  • Screw 1/4"-20
  • Masterfully Crafted Axis Arm
    The carbon fiber axis arm improves gimbal strength and reduces the total weight, allowing users to execute effortless camera movements.
  • A Payload with Professionals in Mind
    Weighing only 1.3 kg and with a max payload of up to 4.5 kg, DJI RS 2 boasts an ultra-high weight-to-payload ratio that is ideal for professionals.
  • Built-in Touchscreen for Greater Control
    Use the color touchscreen to access smart features, change gimbal settings, and view your tracked target, all at your fingertips.
  • Quick Start Balancing
    Balancing your device is made quick and easy thanks to the dual-layered quick-release plates, the Teflon-coated arms, the fine-tuning knob, and the 3-axis gimbal lock.
  • Expand Your Filming
    With two RSA ports directly on the gimbal, users can enjoy flexible payload solutions and use RS 2 with a jib, slider, cable cam, and other professional accessories.
Got questions?Let us help you.
