Deliver to
Estimated shipping date: 8 Apr., expected arrival date: 16 Apr.
5 018 €
Payloads
  • Further and Clearer ‌Vision
    40MP zoom camera supports up to 34× optical zoom and 400× digital. 3000m max laser rangefinding distance is an approx. 2.5-times increase. [1]
  • Enhanced Night Vision
    Zoom and wide camera support Night Scene mode to improve performance in low light. Zoom camera supports IR Light and NIR Illumination. [2]
  • Powerful Infrared Performance
    1280×1024 resolution is a 4x improvement. [3] UHR Infrared Image function [4] allows clear imaging at higher zoom. Max measurable temperature is 1600° C (2192° F), three times that of the previous generation. [5]
  • Reliable Information Sync
    Experience 30s max pre-recording, media and video transmission encryption with one-click log clearance, and live views via DJI FlightHub 2.
  • Smart Multi-Scenario Operation
    Supports Smart Capture for detailed photos in dramatic lighting conditions. Electronic dehazing [6] improves imaging clarity in haze/fog etc.
  • Environmental Adaptability
    Dust and water resistance rated at IP54,[7] and operational from -20° to 50° C (-4° to 122° F), meeting all-weather operational demands.
  • Zenmuse H30
    Zenmuse H30
  • Lens Cap
    Lens Cap
  • microSD Card (64GB)
    microSD Card (64GB)
  • Storage Case
    Storage Case
  • Lens Cleaning Cloth
    Lens Cleaning Cloth
1. "2.5 times" refers to comparing the longest measurement distance of the laser range finders of the Zenmuse H30 Series and the H20 Series. The measurement range may vary based on the material and shape of the tested object as well as the impact of gimbal angle, environmental light, and weather conditions such as rain or fog. If a laser pulse hits multiple targets, its energy is dispersed, which may reduce the measurable distance. Data measured in a DJI laboratory.
2. IR Light and NIR Illumination are supported only when using the zoom camera. NIR Illumination will only activate after takeoff. If NIR Illumination is enabled first, IR Light will also start simultaneously.
3. Comparing the infrared thermal camera resolutions of the Zenmuse H30 Series and the H20 Series. Data measured in a DJI laboratory.
4. UHR Infrared Image should be enabled in advance. The function turns off when the Night Scene mode is enabled.
5. With an Infrared Density Filter installed, the max measurable temperature can reach 1600° C (2912° F). "Three times" refers to comparing the highest measurable temperatures of the infrared thermal cameras of the Zenmuse H30 Series and H20 Series. Data measured in a DJI laboratory.
6. The Night Scene mode and Electronic Dehazing cannot be used at the same time.
7. Under controlled laboratory conditions, it can achieve an IP54 protection rating by IEC60529 standards. The IP rating is not permanently effective and may decrease due to product wear and tear.
We Value Your Privacy
Cookie Preferences
Have questions? Get help from a DJI expert.
