Zenmuse V1
Zenmuse V1 is DJI's first loudspeaker designed for multi-payload drone platforms. It boasts high volume and long broadcast distance, and supports multiple broadcast modes, making it ideal for scenarios like public safety, emergency rescue, and more.
1. Download and read the safety guidelines and user manual of the compatible aircraft from the DJI official website before using for the first time.
2. When using Zenmuse V1, excessive volume of the speaker may cause a certain degree of harm to people. Please ensure safety.
Zenmuse V1 × 1
Carrying Case × 1
Weight: 690±10 g
Dimensions: 134×119×140 mm (L×W×H)
Rated Power: 30 W
Max Sound Pressure Level: 127 dB@1 m [1]
Effective Broadcast Distance: 500 m [1]
Supported Aircraft: Matrice 300 RTK (requires DJI RC Plus), Matrice 350 RTK
Ingress Protection Rating: IP54 [2]
Operating Temperature: -20° to 50° C (-4° to 122° F)
DJI Matrice 400
Matrice 350 RTK
Matrice 300 RTK
1. Measured in a laboratory environment at 25° C (77° F) . Actual conditions may vary slightly due to software version, audio source, specific environment, and other factors. The final effect is subject to actual use.
2. Under controlled laboratory conditions, it can achieve an IP54 protection rating by IEC60529 standards. The IP rating is not permanently effective and may decrease due to product wear and tear.
