Zignes 100W Solar Panel
The Zignes solar panel leverages solar energy to eco-recharge the DJI Power-series power stations, with a single panel reaching a max charging output of 100 W.
Featuring a foldable design, it is convenient to store and transport, and comes with a stand for easy setup without the need for additional supports.
It includes a 3m extension cable, allowing for flexible placement, such as positioning it in well-lit areas.
Designed with an IP65 rating for dust and water resistance, it accommodates a variety of everyday use scenarios.
Zignes 100W Solar Panel requires the use of a DJI Power Solar Panel Adapter Module (MPPT) or a DJI Power Car Power Outlet to SDC Power Cable (12V/24V)
for connection to the DJI Power-series power stations. Purchase the accessories as needed.
Each DJI Power Solar Panel Adapter Module (MPPT) can then connect to one to three solar panels, while the DJI Power Car Power Outlet to SDC Power Cable (12V/24V) can connect to one solar panel at most.
After-sales Service:
Return Period: 30 days (from the date of receipt of the package)
Exchange Period: 30 days (from the date of receipt of the package)
Warranty Period: 1 year
* After-sales services are provided by DJI.
Zignes 100W Solar Panel × 1
Rated Power: 100 W
Open-circuit Voltage: Max 29 V
Short-circuit Current: Max 6 A
Weight: Approx. 4.1 kg
Unfolded Dimensions: 1286×532×25 mm (L×W×H)
Folded Dimensions: 343×532×50 mm (L×W×H)
Operating Temperature: -20° to 60° C (-4° to 140° F)
