DJI Inspire 3
  • Full-frame 8K ProRes RAW/CinemaDNG
    Features an 8K sensor with internal recording of up to 8K/25fps CinemaDNG video [1] and 8K/75fps Apple ProRes RAW video [1] in full frame.
  • 1/1.8-inch Low-Light FPV Camera
    A new 1/1.8-inch-sensor FPV camera with a 3μm pixel size, 161° ultra-wide DFOV, and the ability to transmit live feeds at up to 1080p/60fps.
  • 360° Pan and Tilt Boost
    Inspire 3 features 360° Pan and Tilt Boost configurations. Tilt Boost allows for obstruction-free 80° upward-angle shooting. [2]
  • O3 Pro Video Transmission
    A max transmission distance of 15 km [3] and 1080p/60fps, 4K/30fps [4] live feeds with low latency. Also features dual control mode.
  • RTK and Waypoint Pro
    Centimeter-level RTK positioning [5] makes flying more stable and accurate, significantly improving features such as the new Waypoint Pro.
  • DJI PRO Ecosystem Support [6]
    Inspire 3 supports the DJI High-Bright Remote Monitor, DJI Master Wheels, and DJI Three-Channel Follow Focus, increasing coordination efficiency.
  • Inspire 3 Aircraft
    Inspire 3 Aircraft
  • Zenmuse X9-8K Air Gimbal Camera
  • TB51 Intelligent Battery
    × 4
  • Inspire 3 Trolley Case
  • Zenmuse X9-8K Air Gimbal Camera Case
Moments By You
    X9-8K Air covers 14+ stops of dynamic range, which captures rich highlight and shadow details in complex lighting scenarios like sunrises and sunsets. High dynamic range brings more possibilities for post-editing, retaining genuine colors even after significant exposure adjustments.
    Building on DJI's mature color science and technology, the DJI Cinema Color System allows the X9-8K Air to retain authentic colors that redefine the look of aerial cinematography. This applies to natural settings and urban landscapes, and also accurately captures skin tones in different environments and lighting conditions. DCCS ensures effortless color matching between X9-8K Air and ground-based cinema cameras such as DJI Ronin 4D, delivering consistent color style from air to ground to meet the needs of film-production post-editing workflows.
    Inheriting the classic transformable configuration of the Inspire series, Inspire 3 uses an all-new design that supports 360° Pan and Tilt Boost structures. When the landing gear is lowered, the gimbal supports obstruction-free 80° upward-angle shooting, enabling cinematographers to capture strikingly innovative shots.
    Using Repeatable Routes, the aircraft will automatically fly on the same route and maintain all preset parameters such as altitude, speed, gimbal angle, and camera settings. Repeating the same flight mission allows cinematographers to effortlessly perform difficult one-takes, or to fly at different times in the same place to easily create long-duration timelapses that capture transitions such as day to night or season to season.
    3D Dolly can simulate a crane, cablecam, or dolly on film sets while going far beyond the limitations of those devices.
Inspire 3 (Zenmuse X9-8K Air)
Inspire 2 (Zenmuse X7)
DJI Inspire 3
DJI Mini 4 Pro Wide-Angle Lens
Flagship Cinematography Drone
Professional Cinematography Drone
8K Full-frame Professional Cinematography Drone
S35 6K Professional Cinematography Drone
USD $16,499
USD $39
Image Quality
Full Frame 8K/75fps
S35 6K/30fps
Full Frame 8K/25fps
S35 6K/30fps
Dual Native ISOEI 800/4000
Native ISOEI 400
14+14+ Stops of Dynamic Range
1414 Stops of Dynamic Range
Safety & Flight Performance
80° Tilt Boost
360° Pan
360° Pan
1/1.8"Ultra-Wide Night-Vision Cam
1/7.5"Night-Vision Cam
Waypoint Pro: Repeatable Routes, 3D Dolly
Waypoint
DJI O3 Pro
(15km, 4K/30, 1080p/60)
DJI Lightbridge 2
(7km, 720p/30)
Omnidirectional Obstacle Sensing
Obstacle Sensing in 3 Directions
28 minsMax Flight Time
23 minsMax Flight Time
1. License key sold separately.
2. Measured using DL 50 mm lens with landing gear lowered and the aircraft hovering in a windless environment.
3. Measured in an unobstructed outdoor environment free of interference, with gimbal camera and lens attached to the aircraft and without other accessories. The above data shows the farthest communication range for one-way, non-return flights under each standard. During your flight, please pay attention to reminders in the app.
4. 4K/30fps live feeds are only available when recording video at 30 fps or below.
5. Before using custom network RTK, contact a local dealer to purchase the service. The D-RTK 2 Mobile Station is sold separately.
6. DJI Transmission, DJI Master Wheels, DJI Three-Channel Follow Focus, and the DJI High-Bright Remote Monitor are sold separately.
