DJI Ronin 4D Flex
- Extendable Gimbal Camera Design
- 2m Gimbal Camera Extension Cable
- Lossless Transmission of High-Speed Image Signals
- 1.8kg Minimum Handheld Weight
- Supports Ronin 4D Hand Grips and Monitors
- Agile Configuration Switches On Set
This extendable solution not only reduces handheld weight, but also enhances shooting flexibility and supports more lens options.
2m Extension Cable
Camera position possibilities are much more flexible. Especially useful for through-shots and movements in narrow spaces like car interiors.
Lossless Image Transmission
Extension cable adopts an ultra-thin coaxial cable, supporting lossless transmission of 8K high-speed signals captured by the X9 camera sensor.
Switching between Flex and the integrated configuration on set is fast and requires no tools, providing greater versatility.
4D Hand Grip + Monitor Support
Natively compatible with Ronin 4D's Hand Grips and Main Monitor for a compact-but-powerful solo operating system with full control of Ronin 4D.
Handheld weight is reduced to 1.8 kg, [1] only around 34% of the total weight. [2] Ideal for users who require mobile, long-duration shooting.
Ronin 4D Flex
Pan Axis Quick-Lock
Ronin 4D Hand Grip Adapter
× 2
Hand Grips Adapter Cable
× 2
What product is Ronin 4D Flex applicable to? What functions does it provide?
DJI Ronin 4D Flex is currently only applicable to Ronin 4D. It separates the main body and the gimbal camera, allowing the recording unit, power supply, and video transmission systems to be stored in the bag while the operator holds only the gimbal camera module. This effectively reduces the handheld weight for users. With accessories like extension rods and suction cups, it helps users to explore more unique angles and unlock creative possibilities.
Do I need to activate Ronin 4D Flex before use?
No.
How do I update the firmware of Ronin 4D Flex?
DJI Ronin 4D Flex does not have independent firmware. When using with Ronin 4D, you need to update Ronin 4D and the gimbal camera to the latest firmware.
To learn about how to update the firmware of Ronin 4D, check the tutorial video Ronin 4D - Firmware Update on the official website.
What scenarios does DJI Ronin 4D Flex fit?
It can be used in any scenario and is especially useful for long handheld one-takes and shooting in narrow spaces like vehicle interiors. From remote head use in narrow spaces for film/television production, quick scene transitions in ad production, or long-duration shooting of documentaries or dancing, Ronin 4D Flex can meet a variety of creative needs and unlock the potential in any shot.
Does Ronin 4D Flex support dual focus motors?
Yes. Ronin 4D Flex supports up to three focus motors.
To use the DJI RS Focus Motor (2022) for controlling zoom, focus, or aperture, mount the DJI RS Focus Motor (2022) to the extended gimbal connector module, update the focus motor to the latest firmware, and connect it to the USB-C port on the bottom of the gimbal.
Focus motors can be used in series.
1. Weight includes the Ronin 4D Flex gimbal connector module, X9-6K Gimbal Camera, X9 Counterweight (106 g), and DL 24mm lens.
2. The total weight includes the Ronin 4D 6K Combo, Ronin 4D Video Transmitter, PROSSD Mount, PROSSD 1TB, and DL 24mm lens.
