DJI Transmission
  • Long-Distance HD Live Feed
    Incorporates O3 Pro video transmission technology that offers an incredible 20,000ft [1]  transmission distance at 1080p/60fps.
  • Unlimited Number of Receivers [2]
    Broadcast mode allows an unlimited number of receivers, convenient for real-time monitoring by multiple teams for enhanced efficiency.
  • Triple-Band Seamless Auto Hopping
    Supports triple-band automatic frequency hopping between 2.4 GHz, 5.8 GHz, and DFS for optimal wireless channel use.
  • End-to-End Ultra-Low Latency
    Use the same chip solution as Ronin 4D, with every link explicitly optimized to provide end-to-end ultra-low transmission latency.
  • Integrated Wireless Receiver
    The DJI High-Bright Remote Monitor[3] integrates monitor and receiver with expansion features and supportive tools for precise control.
  • Remote Gimbal/Focus/Camera Control [4]
    When used with Ronin 4D Hand Grips or DJI Master Wheels, [5] you can remotely control Ronin 2, RS 3 Pro, focus, and camera functions.
  • Independent Recording and Playback [4]
    1080p/60fps H.264 footage can be independently recorded and stored on a microSD card, making it easy to edit samples right on set.
  • DJI Video Transmitter
  • High-Bright Remote Monitor
  • Remote Monitor Hood
    Remote Monitor Hood
  • WB37 Battery Adapter (TX)
  • WB37 Intelligent Battery
    × 2
  • WB37 Battery Charging Hub (USB-C)
  • NP-F Battery Adapter
  • NP-F Battery Adapter (RX)
  • DJI Transmission USB-C Power Cable
  • RS Gimbal Mounting Plate
  • USB-C Cable
    USB-C Cable
  • SDI Cable
    SDI Cable
  • DC Power Cable
    DC Power Cable
  • DC to P-TAP Power Cable
  • Installation Toolkit
  • Protector Case
    Protector Case
  • Ronin Video Transmission Antenna
    × 2
DJI Transmission (Standard Combo)
DJI Transmission (High-Bright Monitor Combo)
For use with production monitors
For portable monitoring or dynamic control solutions
USD $2,169
USD $2,169
SupportedFractional Frame Rates
Not supportedFractional Frame Rates
imgPorts
HDMI IN + HDMI OUT + SDI OUTPorts
imgMetadata Transmission via SDI
DJI Master WheelsDJI PRO Ecosystem
DJI Master Wheels & Other DJI PRO ecosystemDJI PRO Ecosystem
Not supportedLiDAR Focusing
SupportedLiDAR Focusing
1. Measured in Control mode (with Broadcast mode turned off) with FCC compliance in a standard, interference-free environment.
2. Supported in Broadcast mode.
3. If the DJI High-Bright Remote Monitor is needed, purchase the DJI Transmission (High-Bright Monitor Combo).
4. Only supported by DJI Transmission (High-Bright Monitor Combo).
5. Sold separately.
