Osmo Action 5 Pro
  • 4hrs Extended Battery Life
  • Robust Stabilization
  • DJI Microphone Connection
  • Osmo Action 5 Pro
    Osmo Action 5 Pro
    × 2
  • Osmo Action Mini Extension Rod
  • Osmo Backpack Strap Mount
  • Osmo Locking Screw
    Osmo Locking Screw
  • Type-C to Type-C PD Cable
  • Osmo Action Anti-Slip Pad
Moments By You
Osmo Action 5 Pro
Osmo Action 4
Osmo Action 4 Standard Combo
Osmo Action 5 Pro
Osmo Action 4
From USD $319
From USD $199
Imaging Performance
img1/1.3″ CMOS
img1/1.3″ CMOS
imgHigh Dynamic Range for All Video Specifications
1080p/240fpsSlow Motion
Stabilization
imgRockSteady 3.0/3.0+
Main Body
240 minsMax Operating Time
160 minsMax Operating Time
imgOLED & High-Brightness Display
imgLCD & No HDR Display
20 mCaseless Waterproof
18 mCaseless Waterproof
YesBuilt-in Pressure Gauge
47 GBBuilt-in Storage
5. Sold separately.
