Osmo Action 5 Pro Road Cycling Combo
Select Option
Powerful All-New 1/1.3″ Sensor
Subject Tracking, Stay Centered
4hrs Extended Battery Life
Dual OLED High-Brightness Touchscreens
Robust Stabilization
DJI Microphone Connection
Versatile Accessory Ecosystem
Osmo Action 5 Pro
Osmo Action Road Cycling Accessory Kit
Osmo Locking Screw
Type-C to Type-C PD Cable
Osmo Action 5 Pro Rubber Lens Protector
Osmo Action 5 Pro Glass Lens Cover
Osmo Action Anti-Slip Pad
Moments By You
From USD $319
From USD $199
1/1.3″ CMOS
1/1.3″ CMOS
High Dynamic Range for All Video Specifications 4K/60fps High-Dynamic Low-Light Imaging
LCD & No HDR DisplayLet’s Answer Your Questions
What improvements does Osmo Action 5 Pro offer compared with the previous generation?
1. A Next-Gen 1/1.3-Inch Sensor: This sensor boasts an equivalent pixel size of 2.4 μm and a high dynamic range of 13.5 stops, which is 1.5 stops higher than that of Osmo Action 4. Coupled with a 4nm high-performance chip, you can capture clear, sharp imagery with rich highlight and shadow details, even in challenging lighting conditions like urban nights or high-contrast scenarios like sunrise and sunset.
2. Support for 10-bit, D-Log M, and HLG Color Modes: These modes can capture more highlight and shadow details, with over a billion colors, ensuring your footage stands up to rigorous post-production and provides more flexibility for professional, stylized creations. Additionally, Osmo Action 5 Pro's front and rear touchscreens can provide a color-recovered preview of the D-Log M footage, allowing you to precisely control color and brightness to ensure top-quality raw footage.
3. Dual OLED High-Brightness Touchscreens: Both the front and rear screens have been upgraded to OLED high-brightness touchscreens, delivering high contrast and vibrant colors. The rear screen now boasts an impressive peak brightness of 1000 cd/㎡, facilitating easier daytime shooting. Moreover, the screens are larger with extremely narrow bezels. Despite retaining the same camera body size, the screen-to-body ratio has been increased by 16%, enhancing the overall user experience.
4. Enhanced Performance and User Experience: Osmo Action 5 Pro boasts upgraded battery performance to deliver up to 240 minutes of operating time, ushering in the era of 4-hour extended battery life for action cameras. It supports Subject Tracking mode, which intelligently detects the subject's position and dynamically adjusts the composition to keep the subject centered in every frame, even without a gimbal. Featuring a new built-in pressure gauge, Action 5 Pro records and displays real-time water depth and altitude, and automatically starts recording when entering the water and stops recording when exiting the water. It also supports Wi-Fi 6.0 and USB 3.0 high-speed transfers, [7] with wireless transfer speeds up to 80 MB/s, [8] significantly improving the photo/video transfer experience.
What additional accessories are included in the Adventure Combo compared with the Standard Combo? Is it worth buying?
The Adventure Combo includes two additional Extreme Batteries Plus and one 1.5m Extension Rod, providing you with ample power for extended outdoor shooting and allowing for multi-angle selfies during activities like skiing, snowboarding, or more.
Is Osmo Action 5 Pro compatible with accessories from the previous generation?
Osmo Action 5 Pro is compatible with most accessories from the previous generation. For details, refer to the Osmo Action 5 Pro accessory compatibility page. DJI has also introduced new accessories such as the Osmo Action Multifunctional Charging Handle, Osmo Helmet Chin Mount Clip, Osmo Action Cold Shoe Expansion Kit, and Osmo Flexible Mount to help you unlock more versatile shooting capabilities.
Can I mount third-party action camera accessories to Osmo Action 5 Pro?
Yes. You can mount third-party action camera accessories with the Quick-Release Adapter Mount.
What resolution settings does Osmo Action 5 Pro support?
Osmo Action 5 Pro supports the following resolution settings:
4K (4:3): 3840×2880@100/120fps
2.7K (4:3): 2688×2016@100/120fps
What is RockSteady 3.0?
Osmo Action 5 Pro uses RockSteady 3.0 technology to stabilize footage. This Electronic Image Stabilization (EIS) technology is realized by increasing the shutter speed, analyzing the images captured by the CMOS sensor, and compensating by cutting off the edges of these images. In this way, multiple frames are overlaid and finally combined into a single frame that is sharp, clear, and accurately exposed.
What is HorizonSteady?
What video and stabilization specifications does SuperNight mode support? When should I use this mode?
SuperNight mode supports shooting at 1080p (16:9)@24/25/30/48/50/60fps, 2.7K (16:9)@24/25/30/48/50/60fps, and 4K (16:9)@24/25/30/48/50/60fps. You can enable RockSteady 3.0 or RockSteady 3.0+, and choose between standard or wide FOV. It is recommended to use this mode in darker urban night scenes. For city nights with basic lighting, standard video mode will suffice.
Can Osmo Action 5 Pro be used while charging?
Yes. However, Subject Tracking mode and SuperNight mode are only functional when the camera is equipped with a battery. Other modes can be used without a battery, as long as the camera is connected to a power source via a Type-C cable.
What microSD cards does Osmo Action 5 Pro support?
Recommended Models:
SanDisk Extreme PRO 32GB U3 A1 V30 microSDHC
Kingston CANVAS Go! Plus 64GB U3 A2 V30 microSDXC
Kingston CANVAS Go! Plus 128GB U3 A2 V30 microSDXC
Kingston CANVAS Go! Plus 256GB U3 A2 V30 microSDXC
Kingston CANVAS Go! Plus 512GB U3 A2 V30 microSDXC
Lexar Professional 1066x 64GB U3 A2 V30 microSDXC
Lexar Professional 1066x 128GB U3 A2 V30 microSDXC
Lexar Professional 1066x 256GB U3 A2 V30 microSDXC
Lexar Professional 1066x 512GB U3 A2 V30 microSDXC
Kingston Canvas Go! Plus 1T U3 A2 V30 microSDXC
5. Sold separately.
