Deliver to
Estimated shipping date: Apr. 10, expected arrival date: Apr. 17
USD $125
RoboMaster TT
Experience DIY flight with the RoboMaster TT Expansion Kit that includes an open-source controller, dot-matrix display & distance-sensing module, and extension board, which support programming with Arduino, MicroPython, and more. It can be used to upgrade TELLO EDU to RoboMaster TT.
Highlights
More stable with dual-band Wi-Fi
Supports SDK, Arduino, Scratch and MicroPython Supports offline programming
Supports third-party sensors
Tof distance sensing module
Programmable dot-matrix display
Full color LED light
Tips
Please use it together with TELLO EDU or RoboMaster TT.
Open-Source Controller x 1
Dot-Matrix Display & Distance Sensing Module x 1
Extension Board x 1
Micro USB Cable x 1
TT Snap-On Top Cover x 1
Dimensions: 49.5×32×15.2 mm
Wi-Fi: 2.4 GHz , 5.8 GHz
Bluetooth: 2.4 GHz
MCU: ESP32-D2WD, dual-core at 160 MHz, 400 MIPS
Open-Source: Supports SDK, Arduino, Scratch and MicroPython
Expansion: 14-pin expansion port (I2C, UART, SPI, GPIO, PWM, power source)
Programmable LED indicator: Full Color LED
Dimensions: 35.3×31.5×8.6 mm
Dot-Matrix LED: Red and blue LED 8×8
Dot-Matrix Driver function: adjustable 256 global brightness, adjustable single-pixel red and blue LED 256 brightness
Distance Sensing Module: TOF
Maximum Sensing Distance of TOF: 1.2 m (indoors with white wall)
Extension Board
DIY Connection: 14-pin extension port to 2×7 pin, 2.54mm dual in-line package, two reserved positions for 5V/3.3V power indicators, two reserved positions for test indicators
TELLO EDU
RoboMaster TT
We Value Your Privacy
Cookie Preferences
