bannerimg
Deliver to
Free express shipping arrival date: Apr. 22
USD $349
DJI Mic 2
  • Sound Great With the DJI Mic 2
    Capture brilliant audio with the DJI Mic 2's omnidirectional recording. This wireless microphone is optimized for vocals, making handling vlogs, interviews, and more a breeze.
  • When Quietness Matters
    The new intelligent noise cancelling feature [1] effectively reduces environmental noise for clean and clear conversations, even in noisy areas.
  • Extended Battery Life
    Each transmitter and receiver has a remarkable 6-hour operating time, [2] which can be extended to a generous 18 hours with the charging case.
  • 250m (820 ft.) Range
    With powerful anti-interference capability, wireless microphone Mic 2 offers a 250m (820 ft.) max audio transmission range, [3] meeting the needs of most scenarios.
  • All-In-One Storage
    The charging case automatically pairs the receiver and transmitters, so you can get started as soon as you open it up.
  • Versatile and Impressive
    Each transmitter has 8 GB of internal storage for up to 14 hours of uncompressed 48kHz 24-bit audio and 32-bit float internal recording. [4]
  • Extensive Compatibility
    Mic 2 supports USB-C and Lightning outputs, as well as 3.5mm TRS analog output. It is compatible with most cameras, smartphones, and computers.
  • DJI OsmoAudio™
    The transmitter supports direct connection to Osmo Action 5 Pro, Osmo Action 4, or Osmo Pocket 3 without a receiver [5] , delivering premium audio and simplifying your gear and workflow.
  • DJI Mic 2 Receiver
    DJI Mic 2 Receiver
  • DJI Mic 2 Transmitter (Shadow Black)
    × 2
  • DJI Mic 2 Charging Case
  • DJI Mic 2 Camera Audio Cable (3.5mm TRS)
  • DJI Mic 2 Mobile Phone Adapter (Type-C)
  • DJI Mic 2 Mobile Phone Adapter (Lightning)
  • DJI Mic 2 Windscreen
    × 2
  • DJI Mic 2 Clip Magnet
    × 2
  • DJI Mic 2 Carrying Bag
DJI Mic 2
DJI Mic 2 (2 TX + 1 RX + Charging Case)
DJI Mic (2 TX + 1 RX + Charging Case)
DJI Mic 2
Wireless Microphone for Pro-Level Audio
Compact Magnetic Wireless Microphone
From USD $219
From USD $159
imgIntelligent noise cancelling
TX Direct ConnectionOsmo Action 5 Pro
Osmo Action 4
Osmo Pocket 3
Mobile Phone
6 hoursSingle-Charge Battery Life
5.5/5 hoursSingle-Charge Battery Life
18 hoursTotal Operating Time
15 hoursTotal Operating Time
img14 hours, supporting 32-bit float internal recording
img14-hour internal recording
img1.1-inch touchscreen + dial
img0.95-inch touchscreen
1. Intelligent noise cancelling of DJI Mic 2 cannot be enabled when the transmitter is connected to a smartphone via Bluetooth.
2. Tested with both transmitters connected to the receiver, without backup recording, and the receiver connected to a camera with the Camera Audio Cable (3.5mm TRS).
3. Measured with FCC compliance in an unobstructed environment without interference (160 m under CE). Actual transmission distance may vary depending on environment.
4. Internal recording of DJI Mic 2 cannot be used when the transmitter is connected to a smartphone via Bluetooth.
5. DJI Mic 2 transmitters can directly connect to select DJI products (one TX for Osmo Action 4, up to two TX for Osmo Pocket 3 and Osmo Action 5 Pro).
We Value Your Privacy
Cookie Preferences
