DJI Power 1000 Portable Power Station
Select Option
DJI Power 1000
DJI Power AC Power Cable
From USD $359
From USD $399
USB-C Port Max Output Power
Grid PowerCar Power
Solar Power
USB-C Recharging
Grid PowerCar Power
Solar Power
Notes for the United Kingdom, the United States and Canada:
3. Measured 100 cm away from DJI Power 1000 while it was being recharged in the Standard Recharging Mode, and is for reference only.
4. Requires certain accessories, which are sold separately.
5. Each USB-C port supports a max output power of 140 W. The device being charged must support the PD 3.1 protocol and use a USB cable that meets EPR specifications.
6. Data tested under laboratory conditions at 25° C (77° F) and should be used for reference only.
7. Requires the DJI Power Solar Panel Adapter Module (MPPT) and solar panels. The aforementioned accessories are sold separately. The minimum time to fully recharge was measured under 25° C (77° F) laboratory conditions and is for reference only. Actual recharging time is subject to factors like the angle of sunlight and light intensity. Actual user experience may vary. Solar panels from DJI-certified brand Zignes are recommended. To use solar panels not officially recommended by DJI, convert the solar panel connector to an XT60 interface. To prevent damage to the MPPT module and the power station, ensure the open-circuit voltage of each solar panel is less than 30 V. The power output of each solar panel connected to a single XT60 interface should not exceed 200 W, with the total output power of solar panels connected to the entire MPPT module capped at 400 W.
8. Measured under 25° C (77° F) laboratory conditions, being recharged in the 600W Standard Recharge Mode, and at an output power of 1000 W.
9. Based on the correct usage of the product, DJI Power 1000 will have an approximate lifespan of 10 years, calculated on the basis of completing one full recharge/discharge cycle on a daily basis. This data is for reference only. Actual user experience may vary.
10. Charging times measured from 10% to 95% battery for the DJI Mavic 3 Series Intelligent Flight Batteries using DJI Power 1000 (with the corresponding fast charge cable) versus other power station (with a 65W charger).
11. In laboratory conditions of 25° C (77° F), when DJI Power 1000 needs to be recharged after being fully discharged from use at rated power, the wait time for the unit to reach a low enough temperature to begin recharging is reduced by as much as 1 hour compared to traditional power stations.
12. Data measured in a DJI laboratory.
Notes for Other Countries/Regions:
3. Fast charge batteries for DJI Mavic 3 series, DJI Air 3, DJI Inspire 3, and the Matrice 30 series. Requires certain accessories, which are sold separately.
Notes of "Why Choose DJI Power?" section, for the United States, Canada, and European countries:
[1] The 2019 DJI Agras series introduced 9‑minute high‑power fast charging, a proven and reliable technology.
[2] Based on publicly available data as of 2025.
[3]All data are current as of 2025.
[4] Data from DJI Power 2000. Product performance may vary; refer to specific product specifications for details.
[5] *US CNN Best No.1 portable power station
https://www.cnn.com/cnn-underscored/reviews/best-product-launches-2025-07-04
*Yanko Design's Best of IFA 2025
https://www.yankodesign.com/2025/09/07/yanko-designs-best-of-ifa-2025-effortless-intelligence-and-design-driven-innovation/
*Certified by the Japan Disaster Prevention Safety Association; ranked No.1 disaster power supply by My Best.
[6] Based on 90th‑percentile transit times. Actual delivery times vary by region and logistics conditions; please consult customer service for specifics.
[7] Up to 5‑year warranty when purchased from the DJI Official Online Store.
[8] Return and exchange policy: https://www.dji.com/service/policy.
[9] Compatible with consumer products, some enterprise models (Matrice 400/350 RTK not supported) and handheld devices.
