DJI Power 500 Portable Power Station
Select Option
1000W Genuine Stable High-Capacity Power Output
DJI Power 500 provides stable power with a battery capacity of 512 Wh to provide a max output power of 1000 W. [1] It is capable of powering high-wattage appliances such as electric kettles (900 W).
![Fast Charges DJI Drones [3]](//se-cdn.djiits.com/tpc/uploads/core_selling_point/image/f607d789aebdc0eeeee3c2597ddf9d2c@origin.jpg)
Fully Charged in 70 Mins, Quickly Powered Up
When connected to grid power, Power 500 supports 540W and 270W recharging, with the fastest recharge time being 70 minutes for 100% battery. [2]
Safe and Secure
Power 500 has passed 26 product test certifications from the Swiss SGS, ensuring safe use and a 4000-cycle life [4] (approx. 10 years). [5]
Both ports can simultaneously recharge Power 500 at 200 W (max) or provide power at 100 W (max). [6]
Extensive Accessories
Power 500 has dual two-way USB-C ports, dual AC output ports, dual USB-A ports, and one SDC Lite port for extensive charge and recharge options.
![Supports Solar Charging [7]](//se-cdn.djiits.com/tpc/uploads/core_selling_point/image/65d23058e3a6b7b4551e8946be65b764@origin.jpg)
DJI Power 500 can be connected to solar panels through the MPPT module or Power Car Power Outlet to SDC Power Cable, [8] for solar recharging.
DJI Power 500
DJI Power AC Power Cable
Practical 512Wh Power Supply for Charging Multiple Devices
From USD $419
From USD $699
USB-C Port Max Output Power
Grid PowerCar Power
Solar Power
USB-C Recharging
Grid PowerCar Power
Solar Power
How is the safety performance of DJI Power 500?
What is the warranty period of DJI Power 500?
What recharging methods does DJI Power 500 support?
In what ways does DJI Power 500 supply power?
What functions are supported with the SDC Lite port?
1. Available when the product's battery level is above 20%.
2. Tested under laboratory conditions at 25° C (77° F) and should be used for reference only.
3. Fast charge batteries for DJI Mavic 3 series, DJI Air 3/3S, DJI Inspire 3, and the Matrice 30 series. Requires certain accessories, which are sold separately.
4. Measured under 25° C (77° F) laboratory conditions, being recharged in the 270W Standard Recharge Mode, and at an output power of 500 W.
5. Based on the correct usage of the product, DJI Power 500 will have an approximate lifespan of 10 years, calculated on the basis of completing one full recharge/discharge cycle on a daily basis. This data is for reference only. Actual user experience may vary.
6. During power output, the device being charged must support the PD 3.0 protocol. During power input (recharging the power station), the charger must support the PD 3.0 protocol.
7. Solar panels, the DJI Power Solar Panel Adapter Module (MPPT), and the adapter cable required for solar recharging are all sold separately.
8. DJI Power 500 can connect to one DJI Power Solar Panel Adapter Module (MPPT), which can then connect with up to three solar panels. DJI Power 500 can also connect to one solar panel through the DJI Power Car Power Outlet to SDC Power Cable.
9. DJI Power Solar Panel Adapter Module (MPPT) and solar panels are sold separately. The minimum time to fully recharge was measured under 25° C (77° F) laboratory conditions and is for reference only. Actual recharging time is subject to factors like the angle of sunlight and light intensity. Actual user experience may vary. Solar panels from DJI-certified brand Zignes are recommended. To use solar panels not officially recommended by DJI, convert the solar panel connector to an XT60 interface. To prevent damage to the MPPT module and the power station, ensure the open-circuit voltage of each solar panel is less than 30 V. The power output of each solar panel connected to a single XT60 interface should not exceed 200 W, with the total output power of solar panels connected to the entire MPPT module capped at 300 W.
Notes of "Why Choose DJI Power?" section, for the United States, Canada, and European countries:
[1] The 2019 DJI Agras series introduced 9‑minute high‑power fast charging, a proven and reliable technology.
[2] Based on publicly available data as of 2025.
[3]All data are current as of 2025.
[4] Data from DJI Power 2000. Product performance may vary; refer to specific product specifications for details.
[5] *US CNN Best No.1 portable power station
https://www.cnn.com/cnn-underscored/reviews/best-product-launches-2025-07-04
*Yanko Design's Best of IFA 2025
https://www.yankodesign.com/2025/09/07/yanko-designs-best-of-ifa-2025-effortless-intelligence-and-design-driven-innovation/
*Certified by the Japan Disaster Prevention Safety Association; ranked No.1 disaster power supply by My Best.
[6] Based on 90th‑percentile transit times. Actual delivery times vary by region and logistics conditions; please consult customer service for specifics.
[7] Up to 5‑year warranty when purchased from the DJI Official Online Store.
[8] Return and exchange policy: https://www.dji.com/service/policy.
[9] Compatible with consumer products, some enterprise models (Matrice 400/350 RTK not supported) and handheld devices.
![Fast Charges DJI Drones [3]](http://se-cdn.djiits.com/tpc/uploads/core_selling_point/image/f607d789aebdc0eeeee3c2597ddf9d2c@origin.jpg)
![Supports Solar Charging [7]](http://se-cdn.djiits.com/tpc/uploads/core_selling_point/image/65d23058e3a6b7b4551e8946be65b764@origin.jpg)
