DJI Power 1000
  • DJI Power 1000
    DJI Power 1000
  • DJI Power AC Power Cable
  • DJI Power Solar Panel Adapter Module (MPPT)
  • Zignes 100W Solar Panel
    × 3
DJI Power 500
DJI Power 1000
DJI Power 500 Portable Power Station
DJI Power 1000 Portable Power Station
DJI Power 500
DJI Power 1000
512Wh Portable Power Station
1024Wh Portable Power Station
From USD $359
From USD $699
512 WhCapacity
1024 WhCapacity
1000 WMaximum Continuous Output
2200 WMaximum Continuous Output
Approx. 7.3 kgWeight
Approx. 13 kgWeight
4000 CyclesCycle Life
imgUSB-C Port Max Output Power
LFP (lithium ferrophosphate)Cell Chemistry
imgGrid Power
Car Power
Solar Power
USB-C Recharging
imgGrid Power
Car Power
Solar Power
3000 mMax Operating Altitude
3. Fast charge batteries for DJI Mavic 3 series, DJI Air 3, DJI Inspire 3, and the Matrice 30 series. Requires certain accessories, which are sold separately.
