DJI Power 1000 & 100W Solar Panel × 6
Select Option
Genuine Ultra-High-Capacity Power Output
DJI Power 1000 has a battery capacity of 1024 Wh and can provide a stable output at 2200 W until battery runs out. [1] It has a max output power of 2600 W [2] and a peak output of 4400 W.
Fast Charges DJI Drones [3]
Fully Charged in 70 Mins
Safe and Secure Design
Extensive Accessories
Supports Solar Charging [7]
DJI Power 1000
DJI Power AC Power Cable
DJI Power Solar Panel Adapter Module (MPPT)
× 2
Zignes 100W Solar Panel
× 6
From AUD $729
From AUD $999
USB-C Port Max Output Power
Grid PowerCar Power
Solar Power
USB-C Recharging
Grid PowerCar Power
Solar Power
3. Fast charge batteries for DJI Mavic 3 series, DJI Air 3, DJI Inspire 3, and the Matrice 30 series. Requires certain accessories, which are sold separately.
