DJI Power 1000 & 120W Solar Panel × 6
Select Option
DJI Power AC Power Cable
DJI Power Solar Panel Adapter Module (MPPT)
× 2
Zignes 120W Solar Panel
× 6
From USD $359
From USD $699
USB-C Port Max Output Power
Grid PowerCar Power
Solar Power
USB-C Recharging
Grid PowerCar Power
Solar Power
3. Fast charge batteries for DJI Mavic 3 series, DJI Air 3/3S, DJI Inspire 3, and the Matrice 30 series. Requires certain accessories, which are sold separately.
