bannerimg
Deliver to
720 €1 070 €
DJI Power 1000
  • Genuine Ultra-High-Capacity Power Output
    DJI Power 1000 has a battery capacity of 1024 Wh and can provide a stable output at 2200 W until battery runs out. [1] It has a max output power of 2600 W [2] and a peak output of 4400 W.
  • Fast Charges DJI Drones [3]
  • Fully Charged in 70 Mins
  • Safe and Secure Design
  • Dual 140W USB-C Ports, Super Fast Charging
  • Extensive Accessories
  • Supports Solar Charging [7]
  • DJI Power 1000
    DJI Power 1000
  • DJI Power AC Power Cable
  • DJI Power Car Power Outlet to SDC Power Cable (12V/24V)
  • DJI Power SDC to Car Charger Plug Power Cable (12 V)
DJI Power 500
DJI Power 1000
DJI Power 500 Portable Power Station
DJI Power 1000 Portable Power Station
DJI Power 500
DJI Power 1000
512Wh Portable Power Station
1024Wh Portable Power Station
From 529 €
From 649 €
512 WhCapacity
1024 WhCapacity
1000 WMax Continuous Output
img2600W Max Output Power
Approx. 7.3 kgNet Weight
Approx. 13 kgWeight
Up to 4000 CyclesTypical Cycle Life
imgDual USB-C Two-way Ports (100W max)
imgDual USB-C Output Ports (140W max)
YesDo the USB-C Ports Support Power In?
NoDo the USB-C Ports Support Power In?
3Max Solar Panels
6Max Solar Panels
300 WMax Solar Power Input
800 WMax Solar Power Input
3. Fast charge batteries for DJI Mavic 3 series, DJI Air 3/3S, DJI Inspire 3, and the Matrice 30 series. Requires certain accessories, which are sold separately.
We Value Your Privacy
Cookie Preferences
Have questions? Get help from a DJI expert.
