DJI Power 500
  • 1000W Genuine Stable High-Capacity Power Output
    DJI Power 500 provides stable power with a battery capacity of 512 Wh to provide a max output power of 1000 W. [1] It is capable of powering high-wattage appliances such as electric kettles (900 W).
  • Fast Charges DJI Drones [3]
  • Fully Charged in 70 Mins, Quickly Powered Up
    When connected to grid power, Power 500 supports 540W and 270W recharging, with the fastest recharge time being 70 minutes for 100% battery. [2]
  • Safe and Secure
    Power 500 has passed 26 product test certifications from the Swiss SGS, ensuring safe use and a 4000-cycle life [4] (approx. 10 years). [5]
  • Dual 140W USB-C Ports, Super Fast Charging
    Both ports can simultaneously recharge Power 500 at 200 W (max) or provide power at 100 W (max). [6]
  • Extensive Accessories
    Power 500 has dual two-way USB-C ports, dual AC output ports, dual USB-A ports, and one SDC Lite port for extensive charge and recharge options.
  • Supports Solar Charging [7]
    DJI Power 500 can be connected to solar panels through the MPPT module or Power Car Power Outlet to SDC Power Cable, [8] for solar recharging.
  • DJI Power 500
    DJI Power 500
  • DJI Power AC Power Cable
  • DJI Power Car Power Outlet to SDC Power Cable (12V/24V)
  • DJI Power SDC to Car Charger Plug Power Cable (12 V)
Practical 512Wh Power Supply for Charging Multiple Devices
DJI Power 500
DJI Power 1000
DJI Power 500 Portable Power Station
DJI Power 1000 Portable Power Station
DJI Power 500
DJI Power 1000
512Wh Portable Power Station
1024Wh Portable Power Station
From USD $299
From USD $699
512 WhCapacity
1024 WhCapacity
1000 WMaximum Continuous Output
2200 WMaximum Continuous Output
Approx. 7.3 kgWeight
Approx. 13 kgWeight
4000 CyclesCycle Life
imgUSB-C Port Max Output Power
LFP (lithium ferrophosphate)Cell Chemistry
imgGrid Power
Car Power
Solar Power
USB-C Recharging
imgGrid Power
Car Power
Solar Power
3000 mMax Operating Altitude
1. Available when the product's battery level is above 20%.
2. Tested under laboratory conditions at 25° C (77° F) and should be used for reference only.
3. Fast charge batteries for DJI Mavic 3 series, DJI Air 3/3S, DJI Inspire 3, and the Matrice 30 series. Requires certain accessories, which are sold separately.
4. Measured under 25° C (77° F) laboratory conditions, being recharged in the 270W Standard Recharge Mode, and at an output power of 500 W.
5. Based on the correct usage of the product, DJI Power 500 will have an approximate lifespan of 10 years, calculated on the basis of completing one full recharge/discharge cycle on a daily basis. This data is for reference only. Actual user experience may vary.
6. During power output, the device being charged must support the PD 3.0 protocol. During power input (recharging the power station), the charger must support the PD 3.0 protocol.
7. Solar panels, the DJI Power Solar Panel Adapter Module (MPPT), and the adapter cable required for solar recharging are all sold separately.
8. DJI Power 500 can connect to one DJI Power Solar Panel Adapter Module (MPPT), which can then connect with up to three solar panels. DJI Power 500 can also connect to one solar panel through the DJI Power Car Power Outlet to SDC Power Cable.
9. DJI Power Solar Panel Adapter Module (MPPT) and solar panels are sold separately. The minimum time to fully recharge was measured under 25° C (77° F) laboratory conditions and is for reference only. Actual recharging time is subject to factors like the angle of sunlight and light intensity. Actual user experience may vary. Solar panels from DJI-certified brand Zignes are recommended. To use solar panels not officially recommended by DJI, convert the solar panel connector to an XT60 interface. To prevent damage to the MPPT module and the power station, ensure the open-circuit voltage of each solar panel is less than 30 V. The power output of each solar panel connected to a single XT60 interface should not exceed 200 W, with the total output power of solar panels connected to the entire MPPT module capped at 300 W.
